Printer Model: Tronxy X5SA Pro
MCU / Printerboard: Octopus MAX EZ
Host / SBC Sovol Klipper Screen
klippy.log (1.8 MB)
Fill out above information and in all cases attach your klippy.log
file (use zip to compress it, if too big). Pasting your printer.cfg
is not needed
Hi, good people of Klipper- I have a converted Tronxy X5SA Pro, I have squared it up, put an Octopus EZ Max board on it with a Sovol Klipper Screen because I was going to try 6 extruder multi material system. Set it up, lots of issues, finally got everything moving and all fans working (Octo EZ Max boards have the fan polarity reversed, couln’t make the extruder or part fan even run) but now I am trying to get a print to work on it and having no luck. Printer loads from Orca Slicer, temps go up and hold with slight wobble, and system homes, then nothing happens. Here is the console:
Unknown command:"PRINT_END"
2:57 PM
PRINT_END
2:57 PM
Unknown command:"DGUS_PRINT_END"
2:57 PM
Move exceeds maximum extrusion (0.200mm^2 vs 0.006mm^2)
2:57 PM
See the 'max_extrude_cross_section' config option for details
2:55 PM
Retries: 7/8 Probed points range: 0.001250 tolerance: 0.005000
2:55 PM
Making the following Z adjustments:
stepper_z = -0.003743
stepper_z1 = -0.002486
2:55 PM
probe at 75.000,170.000 is z=-2.082494
2:55 PM
probe at 335.000,170.000 is z=-2.083744
2:55 PM
Retries: 6/8 Probed points range: 0.011875 tolerance: 0.005000
2:55 PM
stepper_z = -0.013131
stepper_z1 = -0.001251
2:55 PM
probe at 75.000,170.000 is z=-2.081249
2:55 PM
probe at 335.000,170.000 is z=-2.093124
2:55 PM
Retries: 5/8 Probed points range: 0.038125 tolerance: 0.005000
2:55 PM
stepper_z = -0.012501
stepper_z1 = 0.025598
2:55 PM
probe at 75.000,170.000 is z=-2.054391
2:55 PM
probe at 335.000,170.000 is z=-2.092516
2:55 PM
Retries: 4/8 Probed points range: 0.041250 tolerance: 0.005000
2:55 PM
stepper_z = -0.020609
stepper_z1 = 0.020585
2:55 PM
probe at 75.000,170.000 is z=-2.059385
2:55 PM
probe at 335.000,170.000 is z=-2.100635
2:55 PM
Retries: 3/8 Probed points range: 0.120000 tolerance: 0.005000
2:55 PM
stepper_z = -0.045615
stepper_z1 = 0.074345
2:55 PM
probe at 75.000,170.000 is z=-2.005632
2:54 PM
probe at 335.000,170.000 is z=-2.125632
2:54 PM
Retries: 2/8 Probed points range: 0.202500 tolerance: 0.005000
2:54 PM
stepper_z = -0.084993
stepper_z1 = 0.117460
2:54 PM
probe at 75.000,170.000 is z=-1.962516
2:54 PM
probe at 335.000,170.000 is z=-2.165016
2:54 PM
Retries: 1/8 Probed points range: 0.397500 tolerance: 0.005000
2:54 PM
stepper_z = -0.176859
stepper_z1 = 0.220568
2:54 PM
probe at 75.000,170.000 is z=-1.859391
2:54 PM
probe at 335.000,170.000 is z=-2.256891
2:54 PM
Retries: 0/8 Probed points range: 0.760625 tolerance: 0.005000
2:54 PM
stepper_z = -0.561859
stepper_z1 = 0.198735
2:54 PM
probe at 75.000,170.000 is z=-1.881250
2:54 PM
probe at 335.000,170.000 is z=-2.641875
2:54 PM
Move exceeds maximum extrusion (0.902mm^2 vs 0.006mm^2)
2:54 PM
2:54 PM
2:54 PM
2:49 PM
save_last_file
2:49 PM
PRINT_START
2:49 PM
BED_MESH_PROFILE LOAD=default
2:49 PM
File selected
2:49 PM
File opened:3_three_PLA_50m27s.gcode_23.1998 g weight.gcode Size:3062279
I have removed all start code, but left layer and end codes in the slicer. Temp variance is 1 degree either way on the hot end. Bed .5 degree either way.
