! Move exceeds maximum extrusion
Printer Model: Ender 3 V2
MCU / Printerboard: v4.2.2
klippy.log - my klippy.log is nothing but Stats lines every 1 second.
I Just setup installed the Creality Sprite Pro extruder and have been struggling to get it to print anything. I think I’ve made a mistake by using klipper, but I’m trying to figure it out.
My latest issue is trying to print the pressure advance square tower and am getting a failure I have no clue what to do with.
I have sliced the tower with Cura and sent it to fluidd to print and it starts to print and then fails within seconds with
// Moving filament tip 0.0mms
17:26:21
// KAMP purge is using firmware retraction.
17:26:21
// KAMP purge starting at 102.8045, 40.79 and purging 30.0mm of filament, requested flow rate is 12.0mm/s3.
17:26:30
echo: Print Started
17:26:47
// Move exceeds maximum extrusion (8.700mm^2 vs 5.000mm^2)
// See the 'max_extrude_cross_section' config option for details
17:26:47
!! Move exceeds maximum extrusion (8.700mm^2 vs 5.000mm^2)
17:26:47
!! SDCARD_RESET_FILE cannot be run from the sdcard
17:26:47
You know, it would be a lot easier to help if you included your klippy.log.
It’s the file that is “nothing but Stats lines every 1 second.” but there’s other information there that’s required to understand what’s happening.
Please post you klippy.log.
klippy.zip (26.9 KB)
You have over 500 lines of macros - where did you get them?
More importantly: how did you validate them?
The first thing you should do is delete all the Macros (with maybe the exception of CANCEL_PRINT, RESUME & PAUSE) and try to run your print job again.
From there, we can work through any problems that arise.
Hey there! I could use your help with my 3D printer issue. You seem quite knowledgeable. I don’t know how to DM you yet
Post it here on the Klipper Discourse Group.
I’m sure somebody can help you.
I have discovered the problem. It was painfully not obvious, but the START_PRINT macro was putting the printer in relative mode and the slicer was expecting absolute mode. Once I added another M82 at the bottom end of the START_PRINT macro, it started working…smh
I’m glad you found your problem.
