Printer doesn't seem to be following gcode in files
Printer Model: custom printer
MCU / Printerboard: octopus v1.1
Host / SBC raspberry pi 4 4gb
I’m new to klipper and relatively new to 3D printing
I have built my own custom printer and everything seems to be working fine. All axis home home quad bed leveling works fine.
Problem is when I try and print a file it follows the g code under start print. Then when it gets to the model it’s just goes all the way to the opposite corner to 0,0 and crashes.
I’ve looked at the g code file at there doesn’t seem to be anything wrong with it. The first line is telling the machine to go to the centre of the bed
I can add any files that might help later I’m just not home right now
Any help would be
Hello @anstcronious !
The template asked for the klippy.log.
Please attach it to your next post.
Also: How did you setup the origin in the slicer?
Hi @EddyMI3D
I set the shape of the bed in the printer settings and set the and then set 0,0 to the front left corner.
I’m using prusa slicer not sure if that will help
klippy (7).log (5.3 MB)
