Some error during printing
Printer Model: ender 3
MCU / Printerboard: 1.1.5
`klippy.
klippy(3).log (67.7 KB)
hello..
i’have a problem when i print: terminal repeat with redundancy some error:
Unknown command:“HOME”
18:26:55 // Unknown command:“MOVE”
18:26:55 // Unknown command:“WAIT”
18:28:43 // Unknown command:“SET”
19:56:13 // Unknown command:“TURN”
19:56:13 // Unknown command:“MOVE”
19:56:15 // Unknown command:“RAISE”
19:56:15 // Unknown command:“DISABLE”
i don’t understand …
please help me!
thank you
Please make yourself familiar how a 3D printer works in general. There are enough guides everywhere in the www.
None of the commands you listed are valid printer commands.
thank you for your reply.
i use prusaslicer for generate the gcode but when i launch the print this errors appear in terminal.
i’ve search a solution in www but i have found anything about this errors.
i don’t understand if this errors are in gcode or in other part
Maybe you can slice a tiny model and upload the generated gcode-file here.
Seems that your slicer substitutes some commands or works with not yet defined macros.
test.gcode (22.0 KB)
thank you for help me!
[gcode_macro START_PRINT]
gcode =
	{% set BED_TEMP = params.BED_TEMP|default(40)|float %}
	{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(200)|float %}
	Start bed heating
	M140 S{BED_TEMP}
	Use absolute coordinates
	G90
	Reset the G-Code Z offset (adjust Z offset if needed)
	SET_GCODE_OFFSET Z=-1.150
	Home the printer
	G28
	BED_MESH_PROFILE load=default
	Move the nozzle near the bed
	G1 Z5 F3000
	Move the nozzle very close to the bed
	G1 Z0.15 F300
	Wait for bed to reach temperature
	M190 S{BED_TEMP}
	Set and wait for nozzle to reach temperature
	M109 S{EXTRUDER_TEMP}
You turned comments in your macro into commands. Replace this by:
gcode =
	# Start bed heating
	M140 S{BED_TEMP}
	# Use absolute coordinates
	G90
	# Reset the G-Code Z offset (adjust Z offset if needed)
	# Home the printer
	G28
	G1 Z5 F3000
	G1 Z0.15 F300
	# Wait for bed to reach temperature
	M190 S{BED_TEMP}
	# Set and wait for nozzle to reach temperature
Edit:
I would advice against adding a static SET_GCODE_OFFSET Z=-1.150 as this will likely throw off your process.
Thank you very much!
