Problem mcu ‘mcu’: Unable to connect
[v] Printer Model: Neptune 4 pro
[v] MCU / Printerboard:
[v
klippy.log (65.0 KB)
] klippy.log
Hello everyone. I’m having this problem that started to occur overnight.
“mcu ‘mcu’: Unable to connect
config, and restart the host software. Error configuring printer.”
in printer.cfg in mcu line i have this:
serial: /dev/ttyS0
restart_method: command
Anyone can help me pls?
Hello @brvnomartins !
Have you cheked the USB connection to the Printer for proper functionality?
Hi @EddyMI3D.
Are you talking about the external USB port? If so, yes it is working. I did the fix patch and update to the new version of elegoo directly via USB 4 times. I also tried directly via SHH without success.
When the machine go on, it gives this attached image.
