hi,
I know this is a question that may not correspond to this forum, but I don’t know where to ask it.
I am trying to configure a canbus, mellow sht42. And after modifying the configuration, it gives me this error at the beginning.
to Rpi, I have connected the Octopus board and in Mellow sht42 by USB
“‘SHT42’: Invalid CAN uuid”
I have connected by Shh and I have sent the command
“ls -l /dev/disk/by-uuid”
Getting this response…
total 0
lrwxrwxrwx 1 root root 15 May 25 04:31 0213-DFD6 → …/…/mmcblk0p1
lrwxrwxrwx 1 root root 15 May 25 04:31 ccbe1f98-54b5-495f-affb-a570a10d0921 → …/…/mmcblk0p2
But the result is not clear to me… if the UUID is:
"“0213-DFD6”
or as it says total: 0 has not found any usb…
however if I send a
“lsusb”, it seems that if it finds it, the response is:
Bus 001 Device 005: ID 0aaa:0bbb Japan CBM Corp.
Bus 001 Device 006: ID 1d50:614e OpenMoko, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Some ideas?
