I have a question about what Klipper is doing during homing of an axis. I am looking at the command/response traffic during G28 X and I see something that doesn’t make sense after the endstop is triggered.
Here is the stepper configuration:
[stepper_x]
step_pin: PD7
dir_pin: PC5
enable_pin: PD6
endstop_pin: ^PC2
rotation_distance: 40
microsteps: 32
full_steps_per_rotation: 200
position_min: 0
position_max: 300
position_endstop: 0
Here is the beginning of the homing sequence:
request[104898760]: trsync_start {'oid': 4, 'report_clock': 108844428, 'report_ticks': 900000, 'expire_reason': 4}
request[104898760]: stepper_stop_on_trigger {'oid': 2, 'trsync_oid': 4}
request[104898760]: trsync_set_timeout {'oid': 4, 'clock': 111844428}
request[104898760]: endstop_home {'oid': 3, 'clock': 108844428, 'sample_ticks': 180, 'sample_count': 4, 'rest_ticks': 15001, 'pin_value': 1, 'trsync_oid': 4, 'trigger_reason': 1}
request[106094985]: queue_digital_out {'oid': 14, 'clock': 108870636, 'on_ticks': 1}
request[106094985]: set_next_step_dir {'oid': 2, 'dir': 0}
request[106094985]: queue_step {'oid': 2, 'interval': 108937719, 'count': 1, 'add': 0}
request[106679908]: queue_step {'oid': 2, 'interval': 48920, 'count': 2, 'add': -14923}
request[106679908]: queue_step {'oid': 2, 'interval': 27183, 'count': 3, 'add': -3119}
request[106679908]: queue_step {'oid': 2, 'interval': 19378, 'count': 4, 'add': -1247}
request[106679908]: queue_step {'oid': 2, 'interval': 15004, 'count': 59, 'add': 0}
request[106692665]: get_clock {}
response[106692665]: clock clock=106692665
response[107252360]: analog_in_state oid=12 next_clock=110852360 value=31296
response[107252360]: analog_in_state oid=17 next_clock=110852360 value=31296
request[107623106]: queue_step {'oid': 2, 'interval': 15001, 'count': 40, 'add': 0}
request[108227142]: queue_step {'oid': 2, 'interval': 15000, 'count': 40, 'add': 0}
request[108827770]: queue_step {'oid': 2, 'interval': 15000, 'count': 40, 'add
All of that makes sense. TRSYNC notifier is setup, the stepper is enabled, the move direction is set, and then a set of step commands are sent. Then, the MCU performs the move while the endstop is periodically checking the pin state.
When the endstop is hit, I see what I would expect:
response[589806154]: trsync_state oid=4 can_trigger=True trigger_reason=0 clock=589806154
request[590009910]: trsync_set_timeout {'oid': 4, 'clock': 592806154}
response[590099148]: trsync_state oid=4 can_trigger=False trigger_reason=1 clock=0
request[590099148]: trsync_trigger {'oid': 4, 'reason': 2}
request[590099148]: endstop_home {'oid': 3, 'clock': 0, 'sample_ticks': 0, 'sample_count': 0, 'rest_ticks': 0, 'pin_value': 0, 'trsync_oid': 0, 'trigger_reason': 0}
request[590099148]: stepper_get_position {'oid': 2}
response[590099148]: stepper_position oid=2 pos=1073704062
request[590099148]: endstop_query_state {'oid': 3}
response[590099148]: endstop_state oid=3 homing=False next_clock=590050382 pin_value=True
request[590099148]: reset_step_clock {'oid': 2, 'clock': 0}
This also makes sense.
However, right after that, Klipper send another set of step commands also in the negative direction without setting up the TRSYNC.
request[590099148]: set_next_step_dir {'oid': 2, 'dir': 0}
request[590099148]: queue_step {'oid': 2, 'interval': 594922958, 'count': 1, 'add': 0}
request[590099148]: queue_step {'oid': 2, 'interval': 48919, 'count': 2, 'add': -14921}
request[590099148]: queue_step {'oid': 2, 'interval': 27183, 'count': 3, 'add': -3119}
request[590099148]: queue_step {'oid': 2, 'interval': 19378, 'count': 4, 'add': -1247}
request[590099148]: queue_step {'oid': 2, 'interval': 15000, 'count': 419, 'add': 0}
request[590099148]: queue_step {'oid': 2, 'interval': 15000, 'count': 400, 'add': 0}
request[590111932]: queue_step {'oid': 2, 'interval': 15000, 'count': 400, 'add': 0}
What is going on here? My expectation would be that after the endstop trigger, Klipper retracts, which would have to be in the positive direction. Yet, the next step direction is still in the negative direction. This sequence of step comands continues without Klipper checking the stepper position.
