Question on new generic_cartesion kinematics
**dmbutyugin:**One year ago, I asked you a question about double z. According to your guidance, I dealt with it all successfully, but now I need to do it again for some reasons. Can you send me 11 files on configuring generic _ cartesian that need to be modified separately ? The link you sent me before has expired ! Please, I can 't graduate on time !
All the features from back then were merged into mainline Klipper, so you don’t need any modifications anymore, you can just install fresh Klipper and that’s it. If you have questions how to configure Klipper, you can create a new topic in the General Questions section here on discourse, and hopefully someone can help you.
Thank you for your reply ! Do you mean to merge to the main line is the following figure 1 ? I have found the 11 files that need to be modified, but I can 't find how the branch 4 of Figure 2 is added ? Or should not be so modified after this year 's update, directly replace all of your merged main lines into Figure 3, and do not need to reconfigure Figure 2 branch 4 ?
Sorry to trouble you again!
You only need to use Klipper3d/klipper → master now
You may want to start with a fresh Klipper install though. And as I said previously, if you have troubles, I recommend you open a new thread in the General troubleshooting section.
