In the past few days, I have been trying to do several prints with both 0.2mm and 0.4mm nozzles and I noticed the print with 0.2mm nozzle fails much earlier. However, in either case, during a longer print it is prone to fail regardless. The error message I keep getting is:
Can not update MCU ‘mcu’ config as it is shutdown
Error configuring printer
This usually happens after several minutes of print time to hours if I’m (un)lucky. Using the “FIRMWARE_RESTART” command seems to solve my problem temporarily, but I would love to know what is actually causing this problem and how I can get it fixed.
This is not an error that happens during printing, and also your log does not reflect this. There are two instances of this error in your log, and both are in the context of Klipper being restarted. This is explained in the link above.
