Printer Model: vcore 31
MCU / Printerboard: octopus max + ebb42
Host / SBC rPi5
Not an issue…
I think I have some play in the hotend, and after testing to calibrate the input shaper, there’s a significant difference between the axes.
Is there any way to view the data captured by the accelerometer without using the script? Perhaps via the console or some kind of manual capture to a file.
The idea is to try manually moving the hotend first, check the screws, and then try moving it again manually. This is to see if the screws I retightened have solved the problem, without having to reassemble the entire printhead and run the test.
