Recently Upgraded to Klipper -- Please help fix bugs
Printer Model: TRONXY X5SA PRO
MCU / Printerboard: MKS MONSTER 8 V2.0 – TMC 2209 with the UART pin enabled
Host / SBC: BTT PI V.1.2
klippy.log klippy.log (64.1 KB)
Hello and thank you for any help in advance. I am very new to Klipper and firmware stuff in general. I have a fairly modded Tronxy with a few bugs. A kind person helped set this up but I feel I may learn a little if I get help this way. Issues are as follows
I cannot get the correct Rotation distance set on my 2 z steppers if I set it to 8 it moves far too much and 16 helps but I feel there is something not right here.
The Resonance tests fail to work on my Accelerometer but is mostly set up from what I can tell. — FLY-ADX345
Can paste config if asked for
This is a cut down config for my stepper_z and stepper_z1 section.
You need to get rotation_distance correct; the micro-steps do not matter from a distance travel point of view, as long as they are the same.
# Rotation Distance for TR8x8 = 8, TR8x4 = 4, TR8x2 = 2
rotation_distance: 4
[stepper_z1]
I think my issue may be in here
# TMC UART configuration
[tmc2208 stepper_x]
uart_pin: PE6
run_current: 0.8
hold_current: 0.5
stealthchop_threshold: 999999
[tmc2208 stepper_y]
uart_pin: PE3
run_current: 0.8
hold_current: 0.5
#[tmc2208 stepper_z]
#uart_pin: PB7
#run_current: 0.8
#hold_current: 0.5
#stealthchop_threshold: 999999
[tmc2208 extruder]
uart_pin: PB3
run_current: 0.8
hold_current: 0.5
sense_resistor: 0.110
#[tmc2208 extruder1]
#uart_pin: PD4
#run_current: 0.8
#hold_current: 0.5
#[tmc2208 extruder2]
#uart_pin: PD0
#run_current: 0.8
#hold_current: 0.5
#[tmc2208 extruder3]
#uart_pin: PD15
#run_current: 0.8
#hold_current: 0.5
#[tmc2208 extruder4]
#uart_pin: PD11
#run_current: 0.8
#hold_current: 0.5
Are you using TMC drivers for the z-steppers as well? If yo, you do not have them specified in the config.
