Hello everyone, fluidd has been giving this message for a few days.
Is there any way to fix this?
Repo has untracked source files: [‘klippy/extras/gcode_shell_command.py’]
This means you have installed an unofficial modification to Klipper and fluidd is notifying you of this fact.
If you did it on purpose and the modification is not causing any issue then there is nothing to fix.
Thank you, no changes have been made.
I installed with kiauh
If I delete this file gcode_shell_command.py,warning message is going
But unfortunately I can’t delete it because I’m using it
Is there another way to run Python scripts ?
Just a question. Cold that be connected to Klipper v0.12.0 Release! ?
yes
klipper
v0.12.0-0-g0d67d9c4
Could you post your klippy.log?
Sorry,
previous file is incorrect
this is the right one
klippy.log (63.4 KB)
No
Yes, KIAUH is offering to install this external module.
As stated before: If you know what it is, if it is not causing issues and if you are in fact using it, then you have to live with this warning.
There is no other way to run external scripts.
Thank you for your answer
