Resume aborted print using x y z probe co ordinates
Printer Model: all
MCU / Printerboard: all
Host / Klipper
klippy.log klipper
resume aborted print using x y z probe co ordinates
why is not simple to resume a print by simply probing the hot end where the position would be able to print from any point with out affecting bed disturbance heating ironing layer not having home due to possible high and width positing and resume keep it simple why ?
Please attach the klippy.log to your next post.
I tried to create a system to recover a print after shutdown in the past, and I eventually concluded it wasn’t that plausible. Here’s why:
  • The bed will cool down and release your print by the time you recover it
  • Changing the homing position of the probe requires a configuration change
  • XY homing isn’t perfectly repeatable every time
  • You’ll have to splice the G-Code manually
Unfortunately, it’s not that “simple”. While it is possible to recover an aborted print, I wouldn’t call it plausible.
