Screen Not Found Error- KlipperScreen
Printer Model: Pulse XE
MCU / Printerboard: Rambo Einsy
klippy.log - not sure it relevant here
OK - New to this group, not new to 3D completely and certainly not new to technology in general. I had everything working properly with KilpperScreen and as was great. Changed from an on-board 3.5" to a 7" LCD and KlipperScreen seems lost now. I have searched everything I can possbily find and have yet to tickle anything to make this work again. I know the screen works and the settings in the config.txt are working as well (used the basic setting I’ve seen everywhere) because I can see the resolution change on boot up. As you can tell, just ending up at the console screen. I am not an expert in Linux but not timid either.. I’m in the process of just burning another image and starting fresh with the 7" from the get go. I have uninstalled and reinstalled KlipperScreen as well. KlipperScreen log only has activity from the last good connection yesterday.. Nothing since the change. Any insight would be greatly appriciated
If there is any other useful info - please ask
Now to go play with my new K1 that was just delivered
Active: active (running) since Tue 2023-05-23 12:07:56 EDT; 9s ago
Main PID: 17009 (KlipperScreen-s)
Tasks: 3 (limit: 2057)
CPU: 78ms
CGroup: /system.slice/KlipperScreen.service
├─17009 /bin/bash /home/pi/KlipperScreen/scripts/KlipperScreen-start.sh
└─17012 /usr/bin/xinit /home/pi/.KlipperScreen-env/bin/python /home/pi/KlipperScreen/screen.py
May 23 12:07:56 mainsailos KlipperScreen-start.sh[17013]: (EE)
May 23 12:07:56 mainsailos KlipperScreen-start.sh[17013]: Fatal server error:
May 23 12:07:56 mainsailos KlipperScreen-start.sh[17013]: (EE) no screens found(EE)
May 23 12:07:56 mainsailos KlipperScreen-start.sh[17013]: Please consult the The X.Org Foundation support
May 23 12:07:56 mainsailos KlipperScreen-start.sh[17013]: at http://wiki.x.org
May 23 12:07:56 mainsailos KlipperScreen-start.sh[17013]: for help.
May 23 12:07:56 mainsailos KlipperScreen-start.sh[17013]: (EE) Please also check the log file at "/var/log/Xorg.0.log>
May 23 12:07:56 mainsailos KlipperScreen-start.sh[17013]: (EE) Server terminated with error (1). Closing log file.
Running command sudo mv /usr/share/X11/xorg.conf.d/99-fbturbo.conf ~ worked for me to get klipperscreen to show up but the resolution is not correct and the touchscreen doesn’t seem to work the greatest.
