Servo causing MCU disconnect
Printer Model: Custom AWD CoreXY
MCU / Printerboard: BTT Octopus 1.1
Host / SBC: RPI 4
I am trying to control a servo for a Euclid dock but when using a larger MG995 Servo the MCU disconnects after sending a servo command. The command does execute as expected. When using a smaller HXT900 9G servo it works as expected, no disconnects. I see in the klippy log an emergency shutdown but I can’t figure out why
MG995 Datasheet: https://www.mpja.com/download/31150mp.pdf
I’m too new and can’t put more than two links so no datasheet for the 9g servo.
klippy.log (110.4 KB)
Where have you the Vcc of the servo connected to?
Maybe it’s a bit too much current for the printer board.
I’m connecting it to the BLTouch port.
