printer: vzbot based custom config
board: robin nano v3 w/ klipper
slicer: orca
logs and videos.zip (7.5 MB)
klippy.log was to big so i compressed it, also put together a gcode file of my last print and video of the issue itself
So, for a litttle over a month i’ve been having this issue where the printer, sometimes at random and sometimes at a specific point/geometry/move, but mostly random, shutsdown due to large temperature drops on extruder.
i can’t make sense of what might’ve been causing these since recently i just installed a brand new voron style/v6 high flow 300c hotend (it began a little after i installed the hotend) and doesnt seen to follow a pattern.
-before the large drop itself leading to the shutdowns, the printer prints just fine, everything works fine
-not sure if it’s just a impression, but i feel like the shutdowns usually happen when i’m printing with higher temps (230/260) i don’t remember much of then happening with pla prints
-also sometime mid print i’ve noticed some temp oscillations, not enough to shutdown, but 5/7/9c temp drops, i just cant find a pattern
-i tried cleaning the board, checking for loose wires and connectors, etc
-wasn’t having any issues for some days, untill now
-More recently (the main issue, since these shutdowns and drops were happening but were not very frequent, but now…) i had 4 prints (similar models with very similar geometry) fail in the exact same spot, in the middle of the first contact layer with the support interface, all 4, same height (layer 282 if you want to check the gcode)
all of that said, yesterday i spent over 4 hours changing all wires and connector from the hotend to the board, cleaned everything, put brand new wires in, started a print and…same thing, on the same spot
