Printer shuts down when starting print
Ender
Ender 3 S1 Pro
HP ProDesk 600 G3
klippy(3).log (4.7 MB)
moonraker(3).log (9.0 KB)
When I initiate the print the extruder homes then shuts down.
There is no shutdown in the logs, but there is definitely something with extruder thermistor:
Stats 659422.6: gcodein=0  mcu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000008 bytes_write=12870 bytes_read=17752 bytes_retransmit=9 bytes_invalid=0 send_seq=903 receive_seq=903 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=203992 freq=84000862 sd_pos=654 heater_bed: target=60 temp=34.7 pwm=1.000 sysload=0.01 cputime=799.596 memavail=13559712 print_time=101.549 buffer_time=0.000 print_stall=0 extruder: target=150 temp=96.2 pwm=1.000
Stats 659423.6: gcodein=0  mcu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000008 bytes_write=12870 bytes_read=17752 bytes_retransmit=9 bytes_invalid=0 send_seq=903 receive_seq=903 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=203993 freq=84000862 sd_pos=654 heater_bed: target=60 temp=34.7 pwm=1.000 sysload=0.01 cputime=799.599 memavail=13559712 print_time=101.549 buffer_time=0.000 print_stall=0 extruder: target=150 temp=96.2 pwm=1.000
Stats 659424.6: gcodein=0  mcu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000008 bytes_write=12870 bytes_read=17752 bytes_retransmit=9 bytes_invalid=0 send_seq=903 receive_seq=903 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=203994 freq=84000862 sd_pos=654 heater_bed: target=60 temp=34.7 pwm=1.000 sysload=0.01 cputime=799.603 memavail=13559712 print_time=101.549 buffer_time=0.000 print_stall=0 extruder: target=150 temp=96.2 pwm=1.000
Stats 659425.6: gcodein=0  mcu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000008 bytes_write=12870 bytes_read=17752 bytes_retransmit=9 bytes_invalid=0 send_seq=903 receive_seq=903 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=203995 freq=84000862 sd_pos=654 heater_bed: target=60 temp=34.7 pwm=1.000 sysload=0.01 cputime=799.607 memavail=13559716 print_time=101.549 buffer_time=0.000 print_stall=0 extruder: target=150 temp=96.2 pwm=1.000
Stats 659426.6: gcodein=0  mcu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000008 bytes_write=12870 bytes_read=17752 bytes_retransmit=9 bytes_invalid=0 send_seq=903 receive_seq=903 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=203996 freq=84000862 sd_pos=654 heater_bed: target=60 temp=34.7 pwm=1.000 sysload=0.01 cputime=799.611 memavail=13559716 print_time=101.549 buffer_time=0.000 print_stall=0 extruder: target=150 temp=96.2 pwm=1.000
Stats 659427.6: gcodein=0  mcu: mcu_awake=0.003 mcu_task_avg=0.000014 mcu_task_stddev=0.000008 bytes_write=12870 bytes_read=17752 bytes_retransmit=9 bytes_invalid=0 send_seq=903 receive_seq=903 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 upcoming_bytes=203997 freq=84000862 sd_pos=654 heater_bed: target=60 temp=34.7 pwm=1.000 sysload=0.01 cputime=799.615 memavail=13559720 print_time=101.549 buffer_time=0.000 print_stall=0 extruder: target=150 temp=96.2 pwm=1.000
Temperature does not increase or change.
I changed the thermistor ans same thing.
I can manually increase the temp of the extruder and the bed with no problem.
I think it may have something to do with the slicer. I recently switched to the prusa sclicer, but when I loaded an old cura file it printed with no problems.
