Ender 3 V2/ Sptite extruder
P HP ProDesk 600 G4
Intel® Core™ i5-8500T × 6
klippy.log (2.0 MB)
moonraker.log (15.9 KB)
I start the print and the printer shuts down halfway through the print.
P HP ProDesk 600 G4
klippy.log (2.0 MB)
Stats 10040.0: gcodein=0 mcu: mcu_awake=0.014 mcu_task_avg=0.000032 mcu_task_stddev=0.000029 bytes_write=2271326 bytes_read=399575 bytes_retransmit=9 bytes_invalid=0 send_seq=39627 receive_seq=39627 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=8 upcoming_bytes=0 freq=72002602 sd_pos=661238 mcu_temp: temp=101.7 heater_bed: target=60 temp=60.6 pwm=0.000 sysload=0.23 cputime=64.030 memavail=13630996 print_time=1241.420 buffer_time=2.274 print_stall=0 extruder: target=210 temp=209.5 pwm=0.437
Stats 10042.0: gcodein=0 mcu: mcu_awake=0.014 mcu_task_avg=0.000032 mcu_task_stddev=0.000029 bytes_write=2274113 bytes_read=400091 bytes_retransmit=9 bytes_invalid=18 send_seq=39673 receive_seq=39673 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=671 freq=72002603 sd_pos=661750 mcu_temp: temp=101.5 heater_bed: target=60 temp=60.4 pwm=0.000 sysload=0.23 cputime=64.044 memavail=13661932 print_time=1242.423 buffer_time=1.193 print_stall=0 extruder: target=210 temp=209.2 pwm=0.445
MCU 'mcu' is_shutdown: Missed scheduling of next digital out event
clocksync state: mcu_freq=72000000 last_clock=89731601234 clock_est=(10012.130 87214861810 72002603.622) min_half_rtt=0.000376 min_rtt_time=9376.043 time_avg=10012.130(843.522) clock_avg=87214861810.631(60735757050.785) pred_variance=3602328.734
Dumping serial stats: bytes_write=2274481 bytes_read=400264 bytes_retransmit=9 bytes_invalid=18 send_seq=39679 receive_seq=39676 retransmit_seq=2 srtt=0.004 rttvar=0.003 rto=0.025 ready_bytes=4481 upcoming_bytes=8
Sent 87 10040.588528 10040.583924 61: seq: 1f, queue_digital_out oid=17 clock=3385550080 on_ticks=3206817, queue_step oid=9 interval=111505 count=3 add=-8203, queue_step oid=2 interval=56487 count=8 add=-895, queue_step oid=5 interval=274216 count=2 add=24939, queue_step oid=9 interval=87839 count=8 add=-3623, queue_step oid=2 interval=51303 count=8 add=1465, set_next_step_dir oid=5 dir=0
Receive: 97 10042.040056 10040.686491 15: seq: 19, analog_in_state oid=16 next_clock=3851722496 value=31175
Receive: 98 10042.067033 10042.054261 11: seq: 1a, clock clock=3832255314
Receive: 99 10042.067196 10042.054261 7: seq: 1a, is_shutdown static_string_id=Missed scheduling of next digital out event
3832255314 - 3385550080 = 446705234
446705234 / 72000000 = 6.2
Hmm…
From the Stats, there is a 2-second pause, and almost zero CPU usage time.
Something is blocking Klipper from doing its own job.
