Printer Model: Ender 5 modified
MCU / Printerboard: BTT SKR2 Rev B
Host / SBC : Rasberry pi 4b+
klippy-3.txt (5.8 MB)
I tried to config Klipper on my ender5 modified but I’ve got an issus with the TMC2209 V1.2 Driver from BIGTREETECH and the Skr2 Rev B on my Ender5 modified with the E3D hemera. I’ve got this same error for all the axis (all the driver) :
Unable to read tmc uart 'stepper_z' register IFCNT
For all the axes, the command : DUMP_TMC STEPPER=stepper_z return for all the axes :
!! Unable to read tmc uart 'stepper_z' register GCONF
13:41 // ========== Queried registers ==========
13:41 // SGTHRS: 00000000
13:41 // TPOWERDOWN: 00000014 tpowerdown=20
13:41 // COOLCONF: 00000000
13:41 // TCOOLTHRS: 00000000
13:41 // TPWMTHRS: 00000000
13:41 // IHOLD_IRUN: 00081010 ihold=16 irun=16 iholddelay=8
13:41 // SLAVECONF: 00000200 senddelay=2
13:41 // ========== Write-only registers ==========
I’ve tried to swap the TMC2209 V1.2 with a TMC2208 V3, that I’ve got under my hand and he works with this one (but I only have one TMC2208…). The drivers worked under marlin and I’ve checked the pin connection and the drivers are alimented under 24V. I I’ve seen some people report the same issus, but I don’t found a solution… Do you have an idea ? Thanks for your help.
Here is my printer.cfg file :
printer.cfg (3.3 KB)
