SKR Mini E3 V3.0 + ADXL345: Hardware SPI (SPI1) startup issue resolved by Software SPI
Printer Model: Ender 3
MCU / Printerboard: BIGTREETECH SKR Mini E3 V3.0 (STM32G0B1)
Host / SBC: Raspberry Pi 4
klippy.log: Unfortunately, I no longer have the log captured while the issue was occurring because it was solved during troubleshooting. Therefore, I cannot provide the original log. I am posting this to document the solution for other users who may experience the same behavior.
Hello,
I would like to report a startup issue that I was able to reproduce and solve.
Hardware:
  • Ender 3
  • SKR Mini E3 V3.0
  • Raspberry Pi 4
  • Generic blue ADXL345 module
Original configuration:
adxl345
axes_map: x,y,z
cs_pin: PD9
spi_bus: spi1
Problem:
When the ADXL345 was connected to the hardware SPI1, Klipper frequently failed to connect after powering on the printer.
The printer stayed in:
“Printer is not ready”
The only way to make it work was:
  1. Disconnect only the ADXL345 GND wire.
  2. Execute FIRMWARE_RESTART.
  3. Reconnect GND.
After that, the accelerometer worked normally.
Troubleshooting performed:
  • Tested two different ADXL345 modules.
  • Verified the 3.3V supply.
  • Measured all SPI pins.
  • Tested series resistor on MISO.
  • Tested power supply capacitors.
  • Verified wiring.
  • Measured voltages on all pins.
None of these solved the problem.
Solution:
I moved the ADXL345 to Software SPI using free IO pins.
Configuration:
adxl345
axes_map: x,y,z
cs_pin: PD0
spi_software_sclk_pin: PD2
spi_software_mosi_pin: PD3
spi_software_miso_pin: PD4
After this change:
  • Klipper starts normally every time.
  • No need to disconnect GND.
  • ACCELEROMETER_QUERY works.
  • TEST_RESONANCES works.
  • SHAPER_CALIBRATE works.
Based on my testing, switching from hardware SPI1 to software SPI completely eliminated the startup issue. I cannot determine whether the root cause is the SPI1 peripheral, the board, or a firmware interaction, but the behavior was consistently reproducible on my setup.
I’m posting this in case it helps someone else or if the developers know why SPI1 behaves differently during startup.
This is not a support request anymore. The issue has already been solved. I’m sharing the solution because it may help other users and to understand why hardware SPI behaves differently from software SPI on this board.
The wiring used in my final solution follows this GitHub guide:
The only difference is that, in my case, the hardware SPI (SPI1) caused startup issues, while the software SPI configuration worked reliably.
Hardware SPI (PD9 / SPI1): Printer failed to initialize when the ADXL345 was already connected.
Software SPI (PD0, PD2, PD3, PD4): Printer starts normally every time and TEST_RESONANCES / SHAPER_CALIBRATE work correctly.
Hello,
Hardware:
  • Ender 3
  • SKR Mini E3 V3.0
  • Raspberry Pi 4
adxl345
axes_map: x,y,z
cs_pin: PD9
spi_bus: spi1
Problem:
  1. Disconnect the ADXL345 GND wire (or alternatively disconnect the SDO/MISO wire).
  3. Reconnect the wire.
During troubleshooting I found that disconnecting either the power (GND) or the SDO/MISO signal allowed Klipper to start correctly, while disconnecting the other SPI signals (CS, MOSI or SCLK) did not. This observation may help identify the source of the startup issue.
  • Verified wiring.
Solution:
Configuration:
adxl345
axes_map: x,y,z
cs_pin: PD0
After this change:
Hello @FabianoD.Moor and welcome to the forum!
Great you have found a solution.
Short remainder: When posting code, please use the Preformatted text feature of the forum editor, else code may become useless. Thank you.
Format
Hello. I had exactly the same problem, so I looked into it myself. The issue turned out to be that this SPI1 is shared with the SD card. First, before Klipper boots, the CS pin is in a floating state. The ADXL345 misinterprets this as CS Low. After that, communication collides during the process of searching for firmware.bin on the SD card, causing the printer to fail to boot.
In my use case, the symptoms were: after connecting the module and powering on, USB was not recognized most of the time (didn’t show up in lsusb); the moment I disconnected the module after power-on, it was recognized; and once recognized in lsusb, the connection remained even if I reconnected the module.
As a solution, there is a method of pulling up the CS pin through a 10k resistor. I haven’t tried it yet.
Entendi, não cheguei a testar o resistor de 10k em pull up, para deixar ele elevado, pois ja havia feito outros teste, e antes de decidir colocar o cs para alto, decidi mudar as ligações, e com isso obtive sucesso, mas sim, pode acabar funcionando o resistor em pull up, não havia testado para ver se o SPI1 estava sendo compartilhado pelo usb, pois nao estou utilizando ele, apenas via wifi os comando, mas interessante o que voce falou, um caso para o pessoal da empresa btt verem isso.
