You are gonna log Into fluidd on you computer, or however you do it. On the left side of the screen is a bunch of icons, I think the 3rd one up from the bottom is ‘configure’ or something similar, click that. Closer to the bottom right are 3 tags, config, logs and docs. Click the config, look for the printer.cfg open that, change what you need to, hit the save and restart firmware and it should be good, you may have to edit the printer.config.bck or something I’m trying to remember what it says. I’m not in front of it… bit same thing save and restart firmware and you should be good to go. If I’m wrong please let me know because I’m gonna have tochange a bunch in the next couple days switching from sonic pad to run everything from an android tablet, and it has been a learning curve. I am still brand new to this…
Soooo… Newbie here. I’ve got an Ender 3 V2 with the Sonic Pad, CR Touch, and Sprite Pro.
I tried some of the things I’ve seen on here (editing the config page things thru the IP address), but my CR touch X and Y offsets still seem to be off. As one other person stated, when trying to use the auto-bed-level function, the CR touch module goes off the bed and, when going down to try to touch the bed, effectively rams the nozzle into the bed surface.
How would one go about editing the CR touch X and Y offsets either on the Sonic Pad itself, or thru the IP address?
Thanks in advance, I just wanna print things haha
Aaaaannnnnddd… I had been misclicking. Sorry, I got it
Thanks for the info guys!
Did you ever sort this out as I have the same thing happening
