Printer Model: flsun sr kingroon kp3s pro and flsun speeder pad
MCU / Printerboard:
Moonraker warning
[server]: Option ‘enable_debug_logging’ is deprecated, see the configuration documention at
Moonraker warning
[database]: Option ‘database_path’ is deprecated, see the configuration documention at
Moonraker warning
[file_manager]: Option ‘config_path’ is deprecated, see the configuration documention at
Moonraker warning
[file_manager]: Option ‘log_path’ is deprecated, see the configuration documention at
Moonraker warning
Unparsed config section [timelapse] detected. This may be the result of a component that failed to load. In the future this will result in a startup error.
Moonraker: timelapse
An error was detected while loading the moonraker component ‘timelapse’. Please check the log file and fix the issue.
followed the steps on github by putting legit klipper on the speeder pad. i was having issues connceting multiple printers. all went good until i rebooted after install and i get these 6 errors and have been searching the net trying to resolve. im new to klipper so please water down the issue and possible fix. help is much needed. thank you!!!
