Hello,
would like to ask for some help, hot to connect and get it run.
specially for 2.2 there is no description I can find…
THX
[bltouch]
sensor_pin: PA0
control_pin: PA2
The FYSETC wiki has all the information. What is missing?
perfect, it runs now!
had to do the whole wiring and chinging some pins, on the board they are doubel used on pins…
BLTouch works fine, all axis are referenced.
now there are some settings needed.
needed to add: z_offset ?
do not get the point, where to offset the bltouch to nozzle.
[probe] is not used on BLTouch, should I import the settings from probe to bltouch section?
- already found a doc, need to go through
printer.cfg (9.2 KB)
