Hi Guys… I found this macro for start_print on the web.
I am still a beginner on these matters, and I am trying to figure out how things work…
To “prime” the extruder, it is supposed to make a line in the front of the printbed. The hotend moves there, and makes the movement of the line, but without extruding any filament…
Could someone throw an eye on it and help me out to see what’s missing there?
Thanks!
# Define in CURA as Start G-code:
# START_PRINT BED_TEMP={material_bed_temperature_layer_0} EXTRUDER_TEMP={material_print_temperature_layer_0}
[gcode_macro START_PRINT]
#Get Printer built volume dimensions
{% set X_MAX = printer.toolhead.axis_maximum.x|default(100)|float %}
{% set Y_MAX = printer.toolhead.axis_maximum.y|default(100)|float %}
{% set Z_MAX = printer.toolhead.axis_maximum.z|default(100)|float %}
#Get Nozzle diameter and filament width for conditioning
{% set NOZZLE = printer.extruder.nozzle_diameter|default(0.4)|float %}
{% set FILADIA = printer.extruder.filament_diameter|default(1.75)|float %}
#Set Start coordinates of priming lines
{% set X_START = 10.0|default(10.0)|float %}
{% set Y_START = 20.0|default(20.0)|float %}
#Calculate Primer line extrusion volume and filament length
{% set PRIMER_WIDTH = 0.75 * NOZZLE %}
{% set PRIMER_HEIGHT = 0.70 * NOZZLE %}
{% set PRIMER_SECT = PRIMER_WIDTH * PRIMER_HEIGHT %}
{% set PRIMER_VOL = PRIMER_SECT * (X_MAX - 3 * X_START) %}
{% set FILA_SECT = 3.1415 * ( FILADIA / 2.0)**2 %}
{% set FILA_LENGTH = 1.55 * PRIMER_VOL / FILA_SECT %}
#Get Bed and Extruder temperature from Slicer GCode
{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(190)|float %}
#Preheat nozzle and bed
M104 S{EXTRUDER_TEMP} T0
M140 S{BED_TEMP}
#Home
G28
#Move up to clean bed
G1 Y{Y_MAX - 20} Z{Z_MAX/4.0} F6000
#Heat nozzle and bed
M190 S{BED_TEMP}
M109 S{EXTRUDER_TEMP} T0
#Precondition extruder
G92 E0
G1 X{X_START} Y{Y_START} Z{PRIMER_HEIGHT} F6000.0
G1 X{X_MAX - 2 * X_START} Y{Y_START} Z{PRIMER_HEIGHT} F2000.0
G1 X{X_MAX - 2 * X_START} Y{Y_START + PRIMER_WIDTH} Z{PRIMER_HEIGHT}
G1 X{X_START} Y{Y_START + PRIMER_WIDTH} Z{PRIMER_HEIGHT} F2000.0
G92 E0
G1 Z2.0 F600
G1 Z0.2 F600
G1 Z2.0 F600
