Printer Model: Kobra Go
MCU / Printerboard: Stock Kobra Go
klippy (3).log (1.5 MB)
gcodes-2024127-13542.zip (3.7 MB)
I have a problem I cannot get hold of, as I lack information on how to further debug this.
I’m printing a fan shroud model, and that specific model always emergency halts the printer in roughly the same spot.
I attached the gcode file and klippy.log.
The error I get is like this (just en excerpt of the log):
Receive: 96 1791996.826356 1791996.818707 14: seq: 12, analog_in_state oid=19 next_clock=3553096064 value=1588
Receive: 97 1791997.056428 1791996.818707 15: seq: 12, analog_in_state oid=12 next_clock=3591736064 value=25704
Receive: 98 1791997.126487 1791996.818707 14: seq: 12, analog_in_state oid=19 next_clock=3603496064 value=1587
Receive: 99 1791997.280476 1791997.277945 12: seq: 13, shutdown clock=3580171006 static_string_id=Command request
Exiting SD card print (position 658946)
Stats 1791998.3: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000020 mcu_task_stddev=0.000017 bytes_write=4421064 bytes_read=652729 bytes_retransmit=331 bytes_invalid=523 send_seq=76996 receive_seq=76996 retransmit_seq=74029 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=11 upcoming_bytes=0 freq=167995743 heater_bed: target=70 temp=69.6 pwm=0.420 raspberry_pi: temp=37.5 sysload=0.07 cputime=92.537 memavail=7506820 print_time=2350.123 buffer_time=1.378 print_stall=0 extruder: target=240 temp=231.6 pwm=1.000
b'stepcompress o=2 i=0 c=6 a=0: Invalid sequence'
Exception in flush_handler
File "/home/siebert/klipper/klippy/toolhead.py", line 427, in _flush_handler
self._flush_lookahead()
File "/home/siebert/klipper/klippy/toolhead.py", line 357, in _flush_lookahead
self.lookahead.flush()
File "/home/siebert/klipper/klippy/toolhead.py", line 176, in flush
self.toolhead._process_moves(queue[:flush_count])
File "/home/siebert/klipper/klippy/toolhead.py", line 354, in _process_moves
self._advance_move_time(next_move_time)
File "/home/siebert/klipper/klippy/toolhead.py", line 312, in _advance_move_time
self._advance_flush_time(flush_time)
File "/home/siebert/klipper/klippy/toolhead.py", line 303, in _advance_flush_time
m.flush_moves(flush_time, clear_history_time)
File "/home/siebert/klipper/klippy/mcu.py", line 938, in flush_moves
raise error("Internal error in MCU '%s' stepcompress"
mcu.error: Internal error in MCU 'mcu' stepcompress
Stats 1791999.3: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000020 mcu_task_stddev=0.000017 bytes_write=4421102 bytes_read=652870 bytes_retransmit=331 bytes_invalid=523 send_seq=76999 receive_seq=76999 retransmit_seq=74029 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=167995740 heater_bed: target=70 temp=69.6 pwm=0.524 raspberry_pi: temp=37.5 sysload=0.07 cputime=92.565 memavail=7507024 print_time=2350.389 buffer_time=0.644 print_stall=0 extruder: target=240 temp=231.6 pwm=1.000
Stats 1792000.3: gcodein=0 mcu: mcu_awake=0.002 mcu_task_avg=0.000015 mcu_task_stddev=0.000015 bytes_write=4421156 bytes_read=653024 bytes_retransmit=331 bytes_invalid=523 send_seq=77003 receive_seq=77003 retransmit_seq=74029 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=167995743 heater_bed: target=70 temp=69.6 pwm=0.543 raspberry_pi: temp=37.0 sysload=0.07 cputime=92.588 memavail=7507024 print_time=2350.389 buffer_time=0.000 print_stall=0 extruder: target=240 temp=231.3 pwm=1.000
Other models print fine, so it might be related to that specific gcode file. Because of this, I’d also rule out communication issues, or would anyone disagree here?
How do I find out which GCODE line is the culprit (if any)?
Which steps could I undertake to understand the problem better and fix it?
Thanks for all the time being put into this great project!
