Stepper Motor overheating tmc2660 Duet WiFi
I’m having trouble with steppers overheating with my default values from my Duet config. Here’s what I had them set to in Duet M906 X1700:1700 Y1800.00 Z1400:1400:1400:1400 E1000.00 I40 ; Set motor currents (mA) and motor.
When I tried that in the Klipper config my steppers ran really hot. I dialed them back 1.2 which helps but I have a large 600x600x670mm printer and I’m afraid of layer shifting. I’m using LDO 42STH60-2004AH steppers, 4v, 2 amp, 2 ohms. These are large steppers. Duet WiFi tmc2660. Also my stepper_z runs warmer than my other z steppers. Does anyone know why I had to dial my current back so much? Thank you.
Here is my tuned back Klipper config.
#__________________________ X ON DRIVE X ____________________________
[stepper_x]
step_pin: PD6
dir_pin: PD11
enable_pin: !PC6
rotation_distance: 32
full_steps_per_rotation: 200
endstop_pin: ^PC14
position_endstop: 0
position_max: 610
homing_speed: 75.0
homing_retract_dist: 5.0
#second_homing_speed: 10
[tmc2660 stepper_x]
cs_pin: PD14 # X_SPI_EN Required for communication
spi_bus: usart1 # All TMC2660 drivers are connected to USART1
interpolate: True # 1/16 micro-steps interpolated to 1/256
run_current: 1.2
sense_resistor: 0.051
idle_current_percent: 20
#__________________________ X1 ON DRIVE E1 ____________________________
[stepper_x1]
step_pin: PD4
dir_pin: PD9
enable_pin: !PC6
[tmc2660 stepper_x1]
cs_pin: PC25 # X_SPI_EN Required for communication
run_current: 1.2
#__________________________ ON DRIVE Y ____________________________
[stepper_y]
step_pin: PD7
dir_pin: !PD12
enable_pin: !PC6
endstop_pin: ^PA2
position_endstop: 0
position_max: 610
homing_speed: 75.0
[tmc2660 stepper_y]
cs_pin: PC9
spi_bus: usart1
interpolate: True
run_current: 1.2
############################ Z Axis ################################
#__________________________ Z ON DRIVE E3 ____________________________
step_pin: PD1
dir_pin: !PD22
enable_pin: !PC6
rotation_distance: 4
gear_ratio: 40:16
position_max: 670
position_min: -1
[tmc2660 stepper_z]
cs_pin: PD24
spi_bus: usart1
interpolate: True
run_current: 1
#_________________________ Z1 ON DRIVE E4 ___________________________
[stepper_z1]
step_pin: PD0
dir_pin: !PD16
enable_pin: !PC6
gear_ratio: 40:16
[tmc2660 stepper_z1]
cs_pin: PD25
spi_bus: usart1
interpolate: True
run_current: 1
#_________________________ Z2 ON DRIVE E5 ___________________________
[stepper_z2]
step_pin: PD3
dir_pin: !PD17
enable_pin: !PC6
gear_ratio: 40:16
[tmc2660 stepper_z2]
cs_pin: PD26
spi_bus: usart1
interpolate: True
run_current: 1
#_________________________ Z3 ON DRIVE E6 ___________________________
[stepper_z3]
step_pin: PD27
dir_pin: !PC0
enable_pin: !PC6
gear_ratio: 40:16
[tmc2660 stepper_z3]
cs_pin: PB14
spi_bus: usart1
interpolate: True
run_current: 1
See Hold_current and run_current -- TMC2209 - #5 by Sineos
Thanks, I’m really glad I asked. I think I have the current figured out but not the second part. I’m guessing the peak current is the same as the phase current in the specs which are phase 2amp. 2 x .707 x .85 = 1.2019 so current setting is 1.2.
The second part went way over my head. Does it have to do with the sense_resistor: 0.051 ? Or do I need to do any other configuration. I’m using the default from the Klipper Duet config.
Matching TMC driver
  • The drivers do some black magic aka IRUN current scale to achieve optimal microstep resolution
  • This can only efficiently do its work when the current requirements of the stepper matches the driver and the driver’s R-Sense value
  • A 2209 with the typical R-Sense of 0.11 Ohm has an ideal RMS working current between ~1.92 A ( VSENSE = 0) and ~0.97 A ( VSENSE = 1)
  • Klipper does an internal VSENSE switching to achieve higher accuracy at current scaling. IIRC, VSENSE = 1 is the optimal working condition
Disclaimer: This is only my understanding and it is very hard to get reliable information on this topic.
The power rating of the TMC drivers depend on their sense resistor.
The driver are kind of intelligent and try to find the best working point of a stepper. As such the TMC driver and chosen sense resistor should half-way match to the stepper motor or this “intelligence” is limited. Prominent example would be a small NEMA14 stepper on a 5160 with >3A power setting.
Maybe an analogy would be a 400 Watt power supply to drive a single LED with 0.5 Watt. While it will work, the power supply will work very inefficient and the internal losses in the power supply be much greater than the load of the LED
The sense_resistor setting should match what’s on the physical board (or stepstick). One can verify the resistance of the physical “sense resistor” by reviewing the board (or stepstick) schematics. The sense_resistor config value isn’t tuned - it’s should be set according to the physical description of the actual sense resistor on the board.
The VSENSE setting is an internal attribute of the tmc driver that is setup when configuring the driver current. That, and the internal tmc driver IRUN setting, are automatically set by Klipper to match the configured run_current specified in the user’s printer.cfg file.
I expect most users coming from other software may be confused by the fact that some other software uses peak coil current while Klipper uses RMS current. To convert from peak current to RMS current, divide the peak current by 1.414 .
