Printer Model: Ender 5+
MCU / Printerboard: BTT octopus 429; EBB42 toolhead
klippy(1).log (5.5 MB)
My printer worked fine for a year, but I had a lot of banding.
I got a belt upgrade kit for the Z axis, after installing it i modified my config to one z motor and took out the Z-tilt option.
I also replaced my 0.6 by a 0.4mm nozzle.
After this, my printer behaves very weird. It doesn’t matter at what temperature I slice a gcode file, it always warms up to 205°C, after the START_PRINT it goes to 190°C. temps I cannot modify from mainsail, but on the klipperscreen I can still change them…
When the printer is idle, I can set the temperatures from mainsail.
I cannot find where this behaviour comes from…
It is because [START_PRINT] puts it 190°C again:
[gcode_macro START_PRINT]
gcode =
{% set X_MAX = printer.toolhead.axis_maximum.x|default(100)|float %}
{% set Y_MAX = printer.toolhead.axis_maximum.y|default(100)|float %}
{% set Z_MAX = printer.toolhead.axis_maximum.z|default(100)|float %}
{% set NOZZLE = printer.extruder.nozzle_diameter|default(0.4)|float %}
{% set FILADIA = printer.extruder.filament_diameter|default(1.75)|float %}
{% set X_START = 10.0|default(10.0)|float %}
{% set Y_START = 20.0|default(20.0)|float %}
{% set PRIMER_WIDTH = 0.75 * NOZZLE %}
{% set PRIMER_HEIGHT = 0.70 * NOZZLE %}
{% set PRIMER_SECT = PRIMER_WIDTH * PRIMER_HEIGHT %}
{% set PRIMER_VOL = PRIMER_SECT * (X_MAX - 3 * X_START) %}
{% set FILA_SECT = 3.1415 * ( FILADIA / 2.0)**2 %}
{% set FILA_LENGTH = 1.55 * PRIMER_VOL / FILA_SECT %}
{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(190)|float %} # <---
M104 S{EXTRUDER_TEMP} T0
M140 S{BED_TEMP}
G28
G1 Y{Y_MAX - 20} Z{Z_MAX/4.0} F6000
M190 S{BED_TEMP}
M109 S{EXTRUDER_TEMP} T0 # <---
G92 E0
G1 X{X_START} Y{Y_START} Z{PRIMER_HEIGHT} F3000.0
G1 X{X_MAX - 2 * X_START} Y{Y_START} Z{PRIMER_HEIGHT} E{FILA_LENGTH} F2000.0
G1 X{X_MAX - 2 * X_START} Y{Y_START + PRIMER_WIDTH} Z{PRIMER_HEIGHT} E{FILA_LENGTH}
G1 X{X_START} Y{Y_START + PRIMER_WIDTH} Z{PRIMER_HEIGHT} E{FILA_LENGTH} F2000.0
G92 E0
G1 Z2.0 F600
G1 Z0.2 F600
G1 Z2.0 F600
Same is for bed with 60°C
You may kick those lines out.
Honestly, there a pre made configs out there with way too much stuff that do way too much nonsens.
Thank you for your reply, I will remove those lines and see what happens.
But why has it worked for a year? I never had these issues before…
I really can’t tell. Maybe a change in the slicer startcode settings?
