Dear Board
installation of Ender3 V1.1.4 board was successful with rpi 3b. i was so happy that it went well throughout the installation. But from past two days im suffering a lot for Z offset.
Here is my problem.
When i home the printer in fluidd, all X Y and Z are stopping after clicking the switch.
earlier in my ender 3 firmware - once z touches the limit switch it raises little and halts and ready for print.
but in klipper, unfortunately i have followed more than 5 times all the steps mentioned in manual but could nt able to lift the nozzle little after touching the switch.
my offset when i calculate was 0.519mm but no way i could raise that up after touching z stop limit switch.
after auto code generation in cfg file using Z_ENDSTOP_CALIBRATE, when i press home again the nozzle stops after clicking the end stop and when i fire a print the nozzle just scratches the surface of bed which is bad.
Mine is stock ender 3, i dont have any probe or BL touch attached. all i have is End stop limit switch.
Please support how to get rid of this issue.
should i need to buy one probe or BL touch because im using Klipper?
Please help me.
Thanks
