Printer Model: Voron 2.4
MCU / Printerboard: Octopus
My issue is the second extruder is moving faster than the first one, even though they’re identical.
I have two hotends and extruders that I want to act as one. I’m doing a mechanically coupled mirror mode, so maybe a bit of an edge case. I used the [extruder_stepper] parameter to sync the second extruder to the 1st, but when I change the flow rate on the 1st extruder it doesn’t update on the second synced extruder stepper. Am I doing something wrong?
The first paragraph about SYNC_EXTRUDER_MOTION located in the extruder section is difficult to comprehend.
step_pin:
dir_pin:
enable_pin:
microsteps:
rotation_distance:
#full_steps_per_rotation:
#gear_ratio:
See the “stepper” section for a description of the above parameters. If none of the above parameters are specified then no stepper will be associated with the nozzle hotend (though a SYNC_EXTRUDER_MOTION command may associate one at run-time).
What does this mean?
Also, having a difficult time understanding MOTION_QUE is referring to as it’s not mentioned anywhere else in the docs.
SYNC_EXTRUDER_MOTION EXTRUDER= MOTION_QUEUE=
Thanks for your help!
