Temperature Calibration modified Eddy-Coil
Printer Model: Voron 2.4
MCU / Printerboard: https://github.com/cad435/StealthburnerFullUSBPD/blob/main/PD-Toolhead/StealthBurner-PD_V1.2_Toolhead_Schematic.pdf
Host / SBC: BananPi
klippy.log (446.7 KB)
OK, so basically I modified my Eddy-Coil which I had laying around and glued a standard generic 3950 NTC directly onto the PCB-Coil inside the Eddy-Probe.
I drilled a holw into the eddy housing , routed the wires and modifed my Toolhead-Board so that I have a additional temperature sensor.
Everything works fine, except when Im trying to calibrate the Eddy Coil with the newly modified Temperature sensor:
No calibration helper registered for [temperature_probe temp_eddy_coil]
Internet says that the coil version is not supported for temperature compensation, due to the missing temperature probe of the eddy-coil.
But as I added the Sensor to the coil I thought that It might be possible now that I have a Temperature sensor…
Any suggestions?
  • cad435
Try:
[probe_eddy_current btt_eddy]
[temperature_probe btt_eddy] # <---- Must "share" names
Ah yes…
I didn’t get what the “share names” is about, in hindsight its pretty clear tbf.
Thank you, works!
