The stepper motors are not working correctly
VORON 2.4.r2 by fysetc
fysetc spider v2.3
stm2209 v3.1
nema 17 motors 17hs19-2004s
RPi 3B+
hi
I am new to 3d printing and faced with the following problem
when the print head is parked, the motors work normally. but if i start moving the arrows of the fluid interface along the Y axis, at some point the head starts moving in two directions at once and a crack appears (see the video link). moreover, only when moving forward. some time ago everything was fine except that when trying to start bed mesh calibrate, the head also moves incorrectly and does not reach the desired points, the calibration process is disrupted. what could be the reason and what other information do I need to provide?
I couldn’t find the right information to solve exactly my problem =(
video https://cloud.mail.ru/public/dSB6/uXcX19bE4
Uploading: klippy (17).log…
UPD. now the crackling appears randomly. it may appear when parking or during calibration of the sample and other movements along the axes. and it can pass everything without problems…
printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000			        #Max 4000
max_z_velocity: 15			#Max 15 for 12V TMC Drivers, can increase for 24V
max_z_accel: 350
square_corner_velocity: 5.0
#      X/Y Stepper Settings
[stepper_x]
##	Connected to X-MOT (B Motor)
step_pin: PE11
dir_pin: PE10
enable_pin: !PE9
rotation_distance: 40
full_steps_per_rotation: 200  #set to 400 for 0.9 degree stepper
endstop_pin: ^PB14
position_min: 0
##	Uncomment below for 250mm build
#position_endstop: 250
#position_max: 250
##	Uncomment for 300mm build
#position_endstop: 300
#position_max: 300
##	Uncomment for 350mm build
position_endstop: 350
position_max: 350
homing_speed: 25   #Max 100
homing_retract_dist: 5
homing_positive_dir: true
##	Make sure to update below for your relevant driver (2208 or 2209)
[tmc2209 stepper_x]
uart_pin: PE7
interpolate: True
run_current: 0.7
hold_current: 0.4
sense_resistor: 0.110
stealthchop_threshold: 0
##  Make sure to update below for your relevant driver (5160)
#[tmc5160 stepper_x]
## Soft SPI
#spi_software_mosi_pin: PE14
#spi_software_miso_pin: PE13
#spi_software_sclk_pin: PE12
#cs_pin: PE7
#interpolate: True
#diag1_pin: PB14
#run_current: 0.800
#hold_current: 0.500
##stealthchop_threshold: 0
[stepper_y]
##	Connected to Y-MOT (A Motor)
step_pin: PD8
dir_pin: PB12
enable_pin: !PD9
full_steps_per_rotation:200  #set to 400 for 0.9 degree stepper
endstop_pin: ^PB13
position_min: 0
##	Uncomment for 250mm build
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_y]
uart_pin: PE15
interpolate: True
run_current: 0.7
hold_current: 0.4
#[tmc5160 stepper_y]
## Soft SPI
#cs_pin: PE15
##diag1_pin: PB13
#interpolate: True
#run_current: 0.8
#hold_current: 0.7
#   Z Stepper Settings
## In Z-MOT Position
## Z0 Stepper - Front Left
step_pin: PD14
dir_pin: PD13
enable_pin: !PD15
gear_ratio: 80:16
##  In Z- Position
endstop_pin: ^PA0
##  Z-position of nozzle (in mm) to z-endstop trigger point relative to print surface (Z0)
##  (+) value = endstop above Z0, (-) value = endstop below
##	Increasing position_endstop brings nozzle closer to the bed
##  After you run Z_ENDSTOP_CALIBRATE, position_endstop will be stored at the very end of your config
#position_endstop: -0.5
#position_max: 240
##	Uncomment below for 300mm build
#position_max: 290
##	Uncomment below for 350mm build
position_max: 340
position_min: -5
homing_speed: 8
second_homing_speed: 3
homing_retract_dist: 3
[tmc2209 stepper_z]
uart_pin: PD10
interpolate: True
run_current: 0.7
hold_current: 0.4
##	In E1-MOT Position
##	Z1 Stepper - Rear Left
[stepper_z1]
step_pin: PE6
dir_pin: !PC13
enable_pin: !PE5
gear_ratio: 80:16
[tmc2209 stepper_z1]
uart_pin: PC14
interpolate: True
run_current: 0.7
hold_current: 0.4
##	In E2-MOT Position
##	Z2 Stepper - Rear Right
[stepper_z2]
step_pin: PE2
dir_pin: PE4
enable_pin: !PE3
gear_ratio: 80:16
[tmc2209 stepper_z2]
uart_pin: PC15
interpolate: true
run_current: 0.7
hold_current: 0.4
##	In E3-MOT Position
##	Z3 Stepper - Front Right
[stepper_z3]
step_pin: PD12
dir_pin: !PC4
enable_pin: !PE8
gear_ratio: 80:16
[tmc2209 stepper_z3]
uart_pin: PA15
interpolate: true
run_current: 0.7
hold_current: 0.4
#   Extruder
##	In E0-MOT Position
step_pin: PD5
dir_pin: PD6
enable_pin: !PD4
##	Update value below when you perform extruder calibration
##	If you ask for 100mm of filament, but in reality it is 98mm:
##	rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
##  22.6789511 is a good starting point
rotation_distance: 22.6789511	#Bondtech 5mm Drive Gears
##	Update Gear Ratio depending on your Extruder Type
##	Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
##	Use 80:20 for M4, M3.1
gear_ratio: 50:17				#BMG Gear Ratio
full_steps_per_rotation: 200	#200 for 1.8 degree, 400 for 0.9 degree
nozzle_diameter: 0.400
filament_diameter: 1.75
##      In E0 OUT Position
heater_pin: PB15
##	Validate the following thermistor type to make sure it is correct
sensor_type: ATC Semitec 104GT-2 #Generic 3950
sensor_pin: PC0 # TE0 Position
min_temp: 10
max_temp: 270
max_power: 1.0
min_extrude_temp: 170
#control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
##	Try to keep pressure_advance below 1.0
pressure_advance: 0.05
##	Default is 0.040, leave stock
pressure_advance_smooth_time: 0.040
[tmc2209 extruder]
uart_pin: PD7
interpolate: false
run_current: 0.5
hold_current: 0.2
#   Bed Heater
[heater_bed]
##	SSR Pin - In BED OUT position
heater_pin: PB4
sensor_type: NTC 100K MGB18-104F39050L32 # Generic 3950
##  Uncomment below for SpiderVersion 1.x
#sensor_pin: PC3 # TB Position
##  Uncomment below for SpiderVersion 2.2
sensor_pin: PB0 # TB Position
##	Adjust Max Power so your heater doesn't warp your bed
max_power: 0.6
min_temp: 0
max_temp: 110
#control: pid
#pid_kp: 58.437
#pid_ki: 2.347
#pid_kd: 363.769
#	Probe
[probe]
##	Inductive Probe - If you use this section , please comment the [bltouch] section
##	This probe is not used for Z height, only Quad Gantry Leveling
##	In Z+ position
##	If your probe is NC instead of NO, add change pin to ^PA3
pin: ^PA3
x_offset: 0
y_offset: 25.0
#z_offset: 0
speed: 10.0
samples: 3
samples_result: median
sample_retract_dist: 3.0
samples_tolerance: 0.006
samples_tolerance_retries: 3
#	Bltouch
#[bltouch]
##	Bltouch - If you use this section , please comment the [probe] section
##	More infomation at : https://www.klipper3d.org/BLTouch.html
##	This bltouch is not used for Z height, only Quad Gantry Leveling
##	In Z+ Position
#sensor_pin: PA0
##	In Y+ Position
#control_pin: PA2
#x_offset: 0
#y_offset: 25.0
#z_offset: 0
#speed: 10.0
#samples: 3
#samples_result: median
#sample_retract_dist: 3.0
#samples_tolerance: 0.006
#samples_tolerance_retries: 3
#	Fan Control
[heater_fan hotend_fan]
##	Hotend Fan - FAN0 Connector
#pin: PB0
pin: PA13
max_power: 1.0
kick_start_time: 0.5
heater: extruder
heater_temp: 50.0
##	If you are experiencing back flow, you can reduce fan_speed
#fan_speed: 1.0
[fan]
##	Print Cooling Fan - FAN1 Connector
#pin: PB1
pin: PA14
max_power: 0.4
##	Depending on your fan, you may need to increase this value
##	if your fan will not start. Can change cycle_time (increase)
##	if your fan is not able to slow down effectively
off_below: 0.10
[heater_fan controller_fan]
##	Controller fan - FAN2 Connector
pin: !PB2
heater: heater_bed
heater_temp: 45.0
#[heater_fan exhaust_fan]
##  Exhaust fan - In E2 OUT Positon
#pin: PB3
#max_power: 1.0
#shutdown_speed: 0.0
#kick_start_time: 5.0
#heater: heater_bed
#heater_temp: 60
#fan_speed: 1.0
#[controller_fan nevermore]
# Nevermore - In E1 OUT Position
#pin: PC8
#kick_start_time: 0.500
#fan_speed: 0.5
#	LED Control
#[output_pin caselight ]
##  Chamber Lighting - In 5V-RGB Position
#pin: PD3
#pwm: true
#shutdown_value: 0
#value:100
#cycle_time: 0.01
#	Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
[safe_z_home]
##	XY Location of the Z Endstop Switch
##	Update -100,-100 to the XY coordinates of your endstop pin
##	(such as 157,305) after going through Z Endstop Pin
##	Location Definition step.
home_xy_position:231,350
speed:100
z_hop:10
[quad_gantry_level]
##	Use QUAD_GANTRY_LEVEL to level a gantry.
##	Min & Max gantry corners - measure from nozzle at MIN (0,0) and
##	MAX (250, 250), (300,300), or (350,350) depending on your printer size
##	to respective belt positions
##	Gantry Corners for 250mm Build
#gantry_corners:
#	-60,-10
#	310, 320
##	Probe points
#points:
#	50,25
#	50,175
#	200,175
#	200,25
##	Gantry Corners for 300mm Build
#gantry_corners:
#	-60,-10
#	360,370
##	Probe points
	50,25
	50,225
	250,225
	250,25
##	Gantry Corners for 350mm Build
gantry_corners:
	-60,-10
	410,420
##	Probe points
	50,25
	50,275
	300,275
	300,25
speed: 100
horizontal_move_z: 10
retries: 5
retry_tolerance: 0.0075
max_adjust: 10
#	Displays
[display]
#	mini12864 LCD Display
lcd_type: uc1701
cs_pin: PC11
a0_pin: PD2
rst_pin: PC10
encoder_pins: ^PC6,^PC7
click_pin: ^!PA8
contrast: 63
#spi_bus: spi1
spi_software_mosi_pin: PA7
spi_software_miso_pin: PA6
spi_software_sclk_pin: PA5
[neopixel fysetc_mini12864]
#	To control Neopixel RGB in mini12864 display
pin: PC12
chain_count: 3
initial_RED: 0.1
initial_GREEN: 0.5
initial_BLUE: 0.0
color_order: RGB
#	Set RGB values on boot up for each Neopixel.
#	Index 1 = display, Index 2 and 3 = Knob
[delayed_gcode setdisplayneopixel]
initial_duration: 1
        SET_LED LED=fysetc_mini12864 RED=1 GREEN=1 BLUE=1 INDEX=1 TRANSMIT=0
        SET_LED LED=fysetc_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=2 TRANSMIT=0
        SET_LED LED=fysetc_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=3
[bed_mesh]
speed: 100
#mesh_min: 40, 40
#mesh_max: 210,210
#mesh_min: 40, 40
#mesh_max: 260,260
mesh_min: 40, 40
mesh_max: 310,310
fade_start: 0.6
fade_end: 10.0
probe_count: 5,5 # Values should be odd, so one point is directly at bed center
algorithm: bicubic
relative_reference_index: 12 # Update when changing probe_count, to ((x points * y points) - 1) / 2. (the center point)
#	Macros
[gcode_macro G32]
    BED_MESH_CLEAR
    G28
    QUAD_GANTRY_LEVEL
    G28
    ##	Uncomment for for your size printer:
    #G0 X125 Y125 Z30 F3600
    ##	Uncomment for 300 build
    #G0 X150 Y150 Z30 F3600
    G0 X175 Y175 Z30 F3600
#[gcode_macro PRINT_START]
#   Use PRINT_START for the slicer starting script - please customise for your slicer of choice
#original config-remove if mod doesnt work
#gcode:
    #G32                            ; home all axes
    #G1 Z20 F3000                   ; move nozzle away from bed
    G32                            ; home all axes
    BED_MESH_CALIBRATE
[gcode_macro PRINT_END]
#   Use PRINT_END for the slicer ending script - please customise for your slicer of choice
    M400                           ; wait for buffer to clear
    G92 E0                         ; zero the extruder
    G1 E-1.0 F3600                 ; retract filament
    G91                            ; relative positioning
    G0 Z1.00 X20.0 Y20.0 F20000    ; move nozzle to remove stringing
    TURN_OFF_HEATERS
    M107                           ; turn off fan
    G1 Z2 F3000                    ; move nozzle up 2mm
    G90                            ; absolute positioning
    G0  X125 Y250 F3600            ; park nozzle at rear
    BED_MESH_CLEAR
[virtual_sdcard]
path: ~/printer_data/gcodes
[pause_resume]
[gcode_macro CANCEL_PRINT]
description: Cancel the actual running print
rename_existing: CANCEL_PRINT_BASE
  TURN_OFF_HEATERS
  CANCEL_PRINT_BASE
## 	Thermistor Types
##   "EPCOS 100K B57560G104F"
##   "ATC Semitec 104GT-2"
##   "NTC 100K beta 3950"
##   "Honeywell 100K 135-104LAG-J01"
##   "NTC 100K MGB18-104F39050L32" (Keenovo Heater Pad)
##   "AD595"
##   "PT100 INA826"
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 39.073
#*# pid_ki = 1.649
#*# pid_kd = 231.509
#*# [extruder]
#*# control = pid
#*# pid_kp = 19.932
#*# pid_ki = 1.080
#*# pid_kd = 91.934
#*# [stepper_z]
#*# position_endstop = -0.280
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# 	  0.085000, 0.095000, 0.097500, 0.110000, 0.060000
#*# 	  -0.000000, 0.010000, 0.035000, 0.035000, -0.030000
#*# 	  -0.022500, -0.012500, 0.000000, 0.005000, -0.042500
#*# 	  0.002500, 0.007500, 0.025000, 0.005000, -0.017500
#*# 	  0.077500, 0.112500, 0.127500, 0.140000, 0.070000
#*# tension = 0.2
#*# min_x = 40.0
#*# algo = bicubic
#*# y_count = 5
#*# mesh_y_pps = 2
#*# min_y = 40.0
#*# x_count = 5
#*# max_y = 310.0
#*# mesh_x_pps = 2
#*# max_x = 310.0
#*# [probe]
#*# z_offset = -4.900
The Voron 2.4 is a corexy printer. Hence, moving in two directions means that one stepper is not turning. sounds like a mechanical (cracking…) or wiring issue of one of the steppers or its drivers…Hard to diagnose over the internet.
thanks for the reply.
is there any way to check the operability of the steppers and wiring?
could it be a matter of microstep, rotation distance, or full steps per revolution?
the config snippet looks ok. to do mechanical troubleshooting (which this looks like), check the thousands of videos on youtube. Cheers
Florian
the problem was solved by changing run_current to the value “1”
