I have some g-code that I can print just fine with klipper on python 2, but with python 3 I end up getting Timer too close errors towards the end of the first layer.
Figured there wasn’t enough info for an actual bug report, but I’ve attached the log file and the g-code in case anyone might know what to look for. I’ve uploaded them as zips to keep the file size under the limit. (the g-code is a 7z file renamed as a zip file)
xy_joint_left_lower_MGN12_0.2mm_ABS_4h49m.zip (3.6 MB)
klippy.zip (426.2 KB)
Thanks!
