TMC Driver error
Printer Model: Modified wanhao D9
MCU / Printerboard: BTT SKR Pico
klippy (4).log (2.5 MB)
TMC ‘extruder’ reports error: DRV_STATUS: c0180010 s2vsa=1(ShortToSupply_A!) cs_actual=24 stealth=1 stst=1
Printer is shutdown
Ive been printingf fine for like 4 day with the new extruder but then got a drive error the other day
and now randomly get them during prints
im using a btt skr pico
with a creality sprite extruder
could be my wiring as im not sure what are the wires coming out of my motor, but then i question why doies it sometimes work fine , like it ran without issue for 3 days
now getting this error:
TMC ‘extruder’ reports error: GSTAT: 00000002 drv_err=1(ErrorShutdown!)
Either:
  • Wiring, e.g. broken cable, connector etc
  • Dead stepper driver
  • Dead stepper
So in terms of wiring, I’m not 100% sure that I have the pin out correct, like I said I seemed right coz it did work but yeah
Well, if you get intermittent errors, then its most likely from the list above. Wrong pins or messed up stepper phases would cause a permanent failure condition.
So had a guy also mentioned stealth chop on the discord chat, I disabled that and seems to be working for now, will update later again, but yeah, lol yesterday morning I did just order a new stepper so yeah😂
