TMC 'stepper_z' reports error: GSTAT: 0000001d reset=1(Reset) uv_cp=1(Undervoltage!)
Printer Model: CR10S PRO
MCU / Printerboard: Manta M4P with TMC2240’s
klippy (8).log (201.4 KB)
whenever i try homing it i get:
TMC ‘stepper_z’ reports error: GSTAT: 0000001d reset=1(Reset) uv_cp=1(Undervoltage!)
This is usually a wiring or power supply issue.
https://www.klipper3d.org/TMC_Drivers.html#tmc-reports-error-uv_cp1undervoltage
I have ran it for a couple minutes and try ed homing it a couple times but nothing changed and it stayed +/- 0.01v so it might be the wiring
Come on you just wanted to show off your nice fluke aren’t you? :wink:
I think if the wires are wrong it should maybe report an open loop or closed loop. But check the wiring against the data sheet of the motor or just swap the motors if the others work fine.
That’s all the info we have to go on, so hopefully you find a problem in the wiring. I can’t offer any other advice.
