I have built a customized Ender 5 Plus (350x350mm) with 4 Tools. Everything works, but the Cable Management sucks this much, i don‘t intend Publisizing it…
My solution is to build a Tool with PogoPin Connectors on both sides. The only physical connection to the Toolhead will be a Tube.
Here‘s my Scenario:
Tool 2 is connected to the Frame and heating up.
I position the Toolhead (Tx) brfore T2 to get a Connection between the Tool and the Toolhead.
I switch the Pins from T2 to Tx.
I lock the Tool, drive away from the Frame. T2 is now physically connected to Tx.
Is it possible for Clipper to manage switching Temperature Sensor Pins?
Greetings, Stef
