Tronxy X5SA Pro With Creality Sprite and Touch
Sprite install requires
  1. fan power pins reversed on ribbon cable
  2. thermistor wires terminated with connector
  3. belt attachment points cut from extruder mounting bracket
  4. Printed mounting block to relocate stock extruder mount plate to back of x carriage (cable attachment
  5. Printed x and y endstop switch mounts.
Recommend printing and installing Z alignment blocks if you don’t have a z-motor sync belt installed.
Macro in config file will automate aligning the motors with the blocks if you don’t have a belt.
Alignment Blocks: Tronxy X5SA Z Axis Alignment Fixture by MarkSpieth - Thingiverse
STL files for Sprite install available on request.
printer.cfg (6.1 KB)
how can i get the STL files for Sprite install?
Files attached.
I print with 1.6mm walls, top & bottom with 35% infill
Supports touching build plate.
Does require longer screws to go through the sandwich of the extruder mount → Main Bracket → Stock extruder bracket (acts as the rear cable mount).
Main Bracket.stl (359.1 KB)
X_EndStop.stl (5.7 MB)
Y_Endstop.stl (4.8 MB)
Let me know if you have any difficulties and I can upload a Youtube video to help out
it would be nice if you could upload a video, i printed the parts but i don`t now how to put everything together
