Files for Tronxy X5SA-400 Pro?
Good day.
I would like to enquire if anyone may perhaps have working Klipper firmware files for a Tronxy X5SA-400 Pro with SKR Mini E3 V3.0 + TFT35 V3.0.1 + Generic 3D touch probe?
I am replacing its stock parts with the ones mentioned above for more accurate bed leveling and ability to more finely tune the Z-Offset as the Stock firmware and screen doesn’t allow for it and is terribly clunky.
I will be installing the firmware with Repetier Server so that i can manage it along other machines connected to the Server.
Hello @Skeeetman !
The printer has minor interest. It just gives the mechanical limits.
As well as the TFT as it is (I assume) meant to run Klipper Screen (a front end like Mainsail, Fluidd or OctoPrint). This will effect Klipper in second place.
Most important are the printer board and extensions to the board like the 3Dtouch.
For the board there is this:
The 3Dtouch can be installed like a BLtouch with some special settings.
https://www.klipper3d.org/BLTouch.html
Only other device it has as a stock extra is the filament runout sensor which is just a basic one that works like an endstop switch.
It’s my first time using klipper so some help would be appreciated.
Does klipper and klipper screen support mesh BL?
Welcome Skeeetman,
You got a lot to read, but the documentation is excellent
https://www.klipper3d.org/Overview.html
I would start with https://klipper.discourse.group/t/klipper-architecture-ecosystem and then https://klipper.discourse.group/t/installing-klipper-with-kiauh
You may find the config for the fil sensor here klipper/config/printer-tronxy-x5sa-pro-2020.cfg at master · Klipper3d/klipper · GitHub
Here is a similar setup like yours
https://www.reddit.com/r/Tronxy/comments/10c9o8l/x5sa_pro_skr_mini_e3_v2_conversion_with_klipper/?rdt=42244
@VFM_Systems posted his config files. Be careful, he uses a bunch of macros!
Yes, but first get the printer running :wink:
Good luck, hcet14
Thank you !, I will have a look at when I have a lot more time. Will give feedback when i have been successful or not :slight_smile:
How would i change the board in a config?. I have one that is STM32G0B1RE. Ones i see are STM32F boards.
