New to Klipper could use so Help
Tronxy X5SA
BTT Octopus v1.1
klippy.log ( Don’t have one yet )
This is my first time using Klipper . I picked up a Tronxy X5sa for dirt cheap and I have a BTT Octopus laying around so I figure now was the best time to try it out . I searched through the example configuration and found a generic one for the Octopus board . I also found the example configuration for the stock Tronxy x5sa board. Now I am trying to figure out to mesh the two together. Any help would be great
Thank you
Why that? Just one is sufficient. I would recommend the Octopus.
What you need is a SBC like a Raspberry Pi
I have a raspberry pi . I am just trying to figure out how to compile the firmware so I can use the octopus on the x5sa . I have never compiled firmware for klipper
Do I use the config for the factory board and just change the pins to match the octopus or does it have to be a custom script
Wow I am honestly shocked . From all I have been reading about Klipper I was under the impression this was a helpful forum. But for almost 3 days not one single piece of advice or anything .
See MCU not seen after flashing SKR 3 EZ - #9 by Sineos
