Hello!
I am trying to get Klipper on my Tronxy. Having some problems with the Troxy board, so this step is necessary for me
I will use a Raspi2 (if it does not work, it can be a 4).
Installed Octoprint (latest version)
made update/upgrade
did git clone clipper - installed
now the buidling micro crontroller, it is the pi?
I can not finde the Arm cortex A7 in the list, what does it mean?
“Atmega, Sam, Asmd, LPC, STMicro,Raspi RP2040, Linus, Host sim”
I do not have the Spider yet, do I need it already connected?
THX
the board arrived, so I power it up with the 24V DC
connect the PI just with USB or the pin-connectors?? where is a step by step manual to get first system alive?
I have not setup my own Spider yet since the printer it will serve is still WIP.
When the ls /dev/serial/by-id/* command delivers no result, then most probably the board is not correctly flashed.
The cfg point to an entry address of 0x08000000 but your screenshot shows 0x08008000
According to the Fysetc Wiki, it should have been as simple as renamining klipper.bin to firmware.bin and copy it to the SD card.
Further it looks like you killed the bootloader now. Not a tradegy:
I already have a running system, time to finde out whats wrong.
combined the generic-spider and the tronxy.cfg
hopefully I did not do too much wrong klippy.log (27.6 KB) printer.cfg (6.0 KB)
is it the only way to run the printer over the OctoPrint, there is no way for a display on the spider, does a display on the pi bring up some more functionallity?
Um, not meant harsh, but I cannot walk you through connecting your board step by step.
There are enough guides how to connect the hardware: setup fysetc spider - Google Search
I’d recommend to connect the basic things from your old printer first and get it running. Klipper will most likely only start working correctly when you have correctly connected your hardware.
Already solved on RMS Amperes, different on Klipper.
Today I will position the borad on the printer and get cooling fans for drivers running
then the first big print will run hopefully.
