For those that got the newest version of the Bluer Plus with 1.8 degree steppers. This config DOES NOT WORK with the original Bluer Plus with 0.9 degree steppers. Display doesn’t work but operates fine.
[stepper_x]
step_pin: PE3
dir_pin: PE2
enable_pin: !PE4
full_steps_per_rotation: 200
rotation_distance: 40
endstop_pin: !PA15
position_endstop: -5
position_min: -5
position_max: 300
homing_speed: 50[stepper_y]
step_pin: PE0
dir_pin: PB9
enable_pin: !PE1
endstop_pin: !PA12
position_endstop: -15
position_min: -15
position_max: 300
homing_speed: 50[stepper_z]
step_pin: PB5
dir_pin: PB4
enable_pin: !PB8
rotation_distance: 8
position_min: 0
position_max: 400[extruder]
step_pin: PD6
dir_pin: !PD3
enable_pin: !PB3
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC3
sensor_pin: PC1
control: pid
pid_kp = 30.429
pid_ki = 1.811
pid_kd = 127.801
min_temp: 0
max_temp: 230[heater_bed]
heater_pin: PA0
sensor_pin: PC0
control: pid
pid_Kp: 325.10
pid_Ki: 63.35
pid_Kd: 417.10
min_temp: 0
max_temp: 130[bltouch]
sensor_pin: ^PA11
control_pin: PA8
x_offset: 17
y_offset: 29
#z_offset: 2.602
speed: 0.5
samples: 3
lift_speed: 3.0
samples_result: average
samples_tolerance: 0.100
samples_tolerance_retries: 2[safe_z_home]
home_xy_position: 150, 150
speed: 50
z_hop: 20
z_hop_speed: 5[bed_screws]
screw1: 27,27
screw1_name: front left screw
screw2: 267,27
screw2_name: front right screw
screw3: 267,267
screw3_name: rear right screw
screw4: 27,267
screw4_name: rear left screw
horizontal_move_z: 8[screws_tilt_adjust]
screw1: 27,27
screw2: 267,27
screw3: 267,267
screw4: 27,267
horizontal_move_z: 10.
speed: 50.
screw_thread: CW-M3[fan]
pin: PB1[filament_switch_sensor filament_sensor]
switch_pin: ^PA4[mcu]
serial: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 #use your own
restart_method: command[printer]
kinematics: cartesian
max_velocity: 500
max_accel: 3500
max_z_velocity: 25
max_z_accel: 100#Mainsail specific settings
[virtual_sdcard]
path: ~/printer_data/gcodes
printer.cfg (3.7 KB)
