Unable to disable temperature checks on extruder without thermistor
Hello!
I am trying to assemble a custom 3d printer that don’t have a heater and thermistor in extruder and i need to disable it. I am defining my extruder as (note any temperature don’t work and this fake one shows -22C in fluidd):
step_pin: gpio14
dir_pin: !gpio13
enable_pin: !gpio15
rotation_distance: 33.500
nozzle_diameter: 0.4
filament_diameter: 1.75
heater_pin: gpio23
sensor_pin: gpio27
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp=-30
max_temp=9999999999
min_extrude_temp=-30
max_extrude_cross_section:2
It is also -22C in the klippy.log.
What i am doing wrong?
See *Klipper Newbie* Error:Invalid homing_positive_dir / position_endstop in 'stepper_x' - #8 by Sineos
Yeah, this is exactly what i am doing, but it shows error still n UI
i
I wired a thermistor to the board and changed min temp to zero and it started working, but it is still not working without one
Did you set both
min_temp=-273.15
min_extrude_temp=-273.15
Yes, i set both but they still don’t work. until i connect an actual probe. Could it be another parameters or UI problem?
