How do i set extruder min_temp to less than 170c?
I cant figure out how to lower min temp.
current printer.cfg in extruder is set to:
min_temp: 0
If i chane that value lets say to 150 then i get this error:
MCU ‘mcu’ shutdown: ADC out of range
Is there smomewhere else where i can lower min temp?
klippy (3).log (70.7 KB)
ADC out of range means that you don’t have a thermistor plugged in for temperature readings, OR your connection pin for the thermistor is incorrect, OR you have a break in the wire to the thermistor.
printer is working fine, there is no adc error when i set min temp to 0.
i just got strange pla that prints better at 175c than 185c, so i want to try 160c and klipper wont go lower than 170c
min_extrude_temp: 170
Under [extruder] section
https://www.klipper3d.org/Config_Reference.html?h=thermist#extruder
i am trying to change that value, but i get adc out of range error when i do so.
works fine with min_temp: set to 0, but wont work at 150, 160, 170
this is my extruder in printer.cfg
step_pin: PB4
dir_pin: !PB3
enable_pin: !PA15
rotation_distance: 22.285 #has to be calibrated by everyone
gear_ratio: 50:17
full_steps_per_rotation: 200
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC4
control: pid
pid_kp: 44.131
pid_ki: 3.678
pid_kd: 132.392
min_temp: 0
max_temp: 260
max_extrude_cross_section: 50.0
Post your klippy.log as anyway requested when opening a request for support here.
ok, added klipper log to first post. log after i changed min_temp to 150
For whatever reason, your bed and extruder are reporting a temperature of 0 as the first value and this is causing the shutdown.
I have no idea why, though.
figured it out.
min_temp: turns out to be min temp for not throwing error.
And like NAPCAL wrote i needed “min_extrude_temp:” (thought it was the same as min_temp). Added this line in printer.cfg and everything works.
Have no clue why “min_extrude_temp:” isnt included in default cfg file
170 is the default; if the default works for you, then it doesn’t have to be present, or it can be commented out.
