Hello
im experiencing a extrude below min temp error without a reason.
The extrude_below_mintemp is set to 170.
My printer is randomly stopping printing with the error, but keeps the heater on and as you can see in the screenshot the temperature curve does not show any anomaly.
Not sure if you ever found a fix to this but another post I read says that there may have been a connection loss between the SBC and the printer which causes it to shutdown the temps. This just happened to me twice.
One possible recommendation (from others) is a better cable.
I switched to another cable I had and will be doing some longer prints this week to test it.
If you have any more info to steer me in the right direction, or if you’re still not 100% sure as to the cause and want to know the results of my cable switch, please respond to this.
