MCU / Printerboard: RPi Zero W + SKR mini E3 v2
klippy.log klippy.log (155.4 KB)
Hello, today I received two GY-291 adxl345 sensors, I have added an arduino nano via usb to the raspberry pi zero w and added the mcu to klipper, the ACCELEROMETER_QUERY gives me back information, but when I do a TEST_RESONANCES AXIS=X klipper turns off. I do not know what can be happening.
I have tried with thick wires and several original arduino nanos as well as reflashing the arduino several times. No matter if the sensor is mounted on the machine or static, it always stops when I do the test.
Also I have tried to connect it directly to the rpi and the same thing happens here the log:
klippy_to_SPI.log (165.6 KB)
