Unable to parse move 'G1 X189.5 \ Y210.0 \ Z10 F6000'
Printer Model: BLV Cube
MCU / Printerboard: Octopus pro
Host / SBC Rasperbery Pi4B
I created this macro with the help of AI. The macro basically makes sure my extruder is in the centre of the bed before trying to calibrate
the G1 is all on 1 line
klippy.log (2.6 MB)
gcode_macro CALIBRATE_Z
description: Move to bed centre, ensure probe deployed, then run calibration
G90
#Move to the centre of the bed at safe Z height
G1 X{printer.configfile.settings.bed_mesh.mesh_min[0] + (printer.configfile.settings.bed_mesh.mesh_max[0] - printer.configfile.settings.bed_mesh.mesh_min[0]) / 2} Y{printer.configfile.settings.bed_mesh.mesh_min[1] + (printer.configfile.settings.bed_mesh.mesh_max[1] - printer.configfile.settings.bed_mesh.mesh_min[1]) / 2} Z10 F6000
# Safety check: deploy probe if not already deployed
{% if printer.probe.last_query == False %}
    RESPOND PREFIX="info" MSG="Probe not deployed. Deploying now..."
    PROBE_DEPLOY
{% else %}
    RESPOND PREFIX="info" MSG="Probe already deployed."
# Run the probe calibration
PROBE_CALIBRATE
thanks
Can you please format this:
also as Preformatted text. It looks a bit messy.
Have you asked the AI what is going wrong?
BTW: What are the backslashes \ doing in that macro?
I removed the \ thanks for that. Will rerun. Hopefully that will have sorted it.
