Unable to set temperature sensor ATC Semitec 104NT-4-R025H42G
I am attempting to add ATC Semitec 104NT-4-R025H42G as my extruder temperature, but it isn’t working and I get an error saying it is an unknown sensor, but the Klipper documentation says it is a common sensor. What am I doing wrong?
The entry should read:
sensor_type: ATC Semitec 104NT-4-R025H42G
And you need to be on pretty much the most recent git version as it has been add just yesterday. See Frequently Asked Questions - Klipper documentation for updating instructions.
Hi there te correct solution is:
from this source: Thermistors for Klipper | LDO Documentation
and datasheet: https://atcsemitec.co.uk/wp-content/uploads/2019/01/Semitec-NT-4-Glass-NTC-Thermistor.pdf
[thermistor ATC Semitec 104NT-4-R025H42G]
temperature1: 25
resistance1: 100000
temperature2: 160
resistance2: 1074
temperature3: 300
resistance3: 82.78
min_temp: -50 #<-- important
max_temp: 300 #<-- important
Your printer is shutdown because min temp is in negative value. See the minimal temp on datasheet i see -50 value.
Regards
I’m not sure what you are reporting in this 2 years old thread and it is also not a “correct solution”
  • The ATC Semitec 104NT-4-R025H42G is natively supported by Klipper and there is no need for a custom thermistor table
  • The min_temp and max_temp settings should be defined according to the capabilities of the hotend and a min_temp of -50 °C typically makes absolutely no sense for a hotend
  • These settings define the lower and upper limits and are used for sanity checks and protection of the hardware. If violated, Klipper will react with an error message
Well after three years you have clarified things that are not where they should be. Since in google these pages appear and not the ones that have a solution.
hi, I have a huge temperature difference with an E3D revo, at 150°C I measure +/-122°C, and at 250°C I measure +/- 200°C…
I have to play with the “pullup_resistor”? Or is there another parameter to look at?
A look into your klippy.log would be helpful…
