Unable to update MCU verison on OctopusPro
Printer Model: Custom Core XY
MCU / Printerboard: Octopus Pro V1.1
Host / SBC: Mainsail
klippy (1).log (1.2 MB)
…I am unable to date the MCU on my octopus pro V1.1 board from V0.10 to V0.12. I have followed the voron docs for this board so i am confident that the menuconfig option are correct. When flashing via serial (with the board in bootloader mode) I get “Error 255” and when trying serialflash I get “Error 1”… Abandoning this approach and copying the firmware.bin file onto an SD card and inserting it into the octopus board, when the board boots it still shows V0.10…
I am at a loss and any words of wisdom would be appreciated.
Also, are there any negative consequences for having the MCU running at older version? Klipper is happy to allow the mis-match, so is it just fine to continue printing?
Please show your settings and the complete output of the flashing command
Make menuconfig
make flash part 1
make flash part 2
and lastly serialflash. Sorry these are single posts, as i am new user the web page would only let me upload one at a time.
Try following approach (your settings seem correct if it really is a F429 MCU):
make clean
make distclean
make menuconfig
make
Put the board into the DFU mode and verify that it is actually in DFU mode with the lsusb command.
Then flash with:
make flash FLASH_DEVICE=1234:5678
Replace 1234:5678 with the device ID from the lsusb command.
Sadly i got the same result
Please show the output of
sudo dfu-util -l
when the board is in DFU mode.
@Yames :
Are you using putty?
You can do text copy & paste. It’s better to read than a screen copy.
I am using Git Bash
[sudo] password for pi:
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Found DFU: [0483:df11] ver=2200, devnum=4, cfg=1, intf=0, path="1-1.1.2", alt=3, name="@Device Feature/0xFFFF0000/01*004 e", serial="207631674730"
Found DFU: [0483:df11] ver=2200, devnum=4, cfg=1, intf=0, path="1-1.1.2", alt=2, name="@OTP Memory /0x1FFF7800/01*512 e,01*016 e", serial="207631674730"
Found DFU: [0483:df11] ver=2200, devnum=4, cfg=1, intf=0, path="1-1.1.2", alt=1, name="@Option Bytes  /0x1FFFC000/01*016 e/0x1FFEC000/01*016 e", serial="207631674730"
Found DFU: [0483:df11] ver=2200, devnum=4, cfg=1, intf=0, path="1-1.1.2", alt=0, name="UNKNOWN", serial="207631674730"
This looks strange. Maybe the bootloader is burned?
If you feel brave, try installing Katapult:
git clone https://github.com/Arksine/katapult
cd katapult
make menuconfig #<------------- Use the same settings as for Klipper
make
Put the board into DFU and then issue:
sudo dfu-util -R -a 0 -s 0x08000000:force:mass-erase:leave -D ~/katapult/out/katapult.bin -d 0483:df11
Then try flashing Klipper as per the command above.
i dont know if I am feeling that brave :). I am off to formnext so I wont be able to reply until Monday, but thank you for your help so far and ill try any suggestions when I return.
its likely this same issue, seems to be an issue with the bootloader.
same error will appear if you try and use dfu to install katapult
did some searching as i have the same board.
the issue can be fixed by updating from dfu-util 0.9 to 0.11
you can do this by compiling a new version like this:
git clone git://git.code.sf.net/p/dfu-util/dfu-util
cd dfu-util
./autogen.sh
./configure  # on most systems
sudo make install
dfu mode now works as expected
pi@Jeff:~ $ git clone git://git.code.sf.net/p/dfu-util/dfu-util
Cloning into 'dfu-util'...
remote: Enumerating objects: 2488, done.
remote: Counting objects: 100% (2488/2488), done.
remote: Compressing objects: 100% (1274/1274), done.
remote: Total 2488 (delta 1801), reused 1660 (delta 1207)
Receiving objects: 100% (2488/2488), 467.02 KiB | 988.00 KiB/s, done.
Resolving deltas: 100% (1801/1801), done.
pi@Jeff:~ $ cd dfu-util
pi@Jeff:~/dfu-util $ ./autogen.sh
./autogen.sh: 2: autoreconf: not found
pi@Jeff:~/dfu-util $ ls
AUTHORS  autogen.sh  ChangeLog  configure.ac  COPYING  device-logs  DEVICES.txt  dfuse-pack.py  doc  INSTALL  Makefile.am  msvc  README  src  TODO  www
Thanks for the suggestion. Do you have any idea why “autoreconf” is not found?
no idea unfortunately, it worked first time when i tried it
maybe try these pre-reqs from the readme
  sudo apt-get build-dep dfu-util
  sudo apt-get install libusb-1.0-0-dev
sudo apt-get install autoconf
Thank you @Sineos and @mjfsch. Updating the DFU-UTIL has sorted the issue, along with running the apt-get install autoconf command
If either of you are visiting SMRRF let me know and ill buy you a beer :slight_smile:
