Unhandled exception during run, while printing from Sd LCD MENU
Basic Information: Unhandled exception during run
Printer Model: Kreator A1
MCU / Printerboard: MKS Gen L v2.1
klippy_ldcF.log (1.4 MB)
Describe your issue: I’m using Graphics LCD 128*64. When trying to print from LCD menu SD Print mainSail os restarts and shows Unhandled exception during run .
Config:
[virtual_sdcard]
path = ~/gcode_files
on_error_gcode =
	CANCEL_PRINT
Error:
virtual_sdcard get_file_list
  File "/home/debian/klipper/klippy/extras/virtual_sdcard.py", line 78, in get_file_list
    filenames = os.listdir(self.sdcard_dirname)
OSError: [Errno 2] No such file or directory: '/home/debian/gcode_files'
/home/debian/gcode_files seems not existing
I have been using just:
[virtual_sdcard]
path: ~/gcode_files
Shouldn’t that cancel print automatically if there is an error returned?
In a Linux path the ~ is expanded to the user’s home folder, so
~/gcode_files is the same as /home/debian/gcode_files (given your current user is debian)
The error handler is meant to react if something goes wrong during a print from the virtual_sdcard and not as a safeguard when the folder does not even exists.
Good to know - then the
> on_error_gcode =
> 	CANCEL_PRINT
statement should be added (always)?
Surely does not hurt. See virtual_sdcard: Adds `on_error_gcode` by pedrolamas · Pull Request #5491 · Klipper3d/klipper · GitHub
Thank you.
I’m going to start a new thread on printer.cfg standards that is an offshoot from this.
