Unknown command:M106
Printer Model: K1 Max
MCU / Printerboard:
klippy.log (1.6 MB)
Having an issue with the fan control on my rooted k1 max.
Getting this message when it should start the fans:
// {“code”:"key61, “msg”:“Unknown command:M106”, “values”: [“M106”]}
All input is appriciated!
A bit novice in this area…
To see the proper format use Fluidd or Mansail, use the fan speed slider then look a the command format in the console output.
I get this type of command if I lower it a bit. Is this what you mean?
$ SET_PIN PIN=fan0 VALUE=242.25
Is this fan defined as a fan_generic?
Used a preset version of klipper for the k1 so I don’t really know…
Where do I check this?
Found this:
[output_pin fan0]
pin: !nozzle_mcu: PB8
pwm: True
cycle_time: 0.0100
hardware_pwm: false
value: 0.00
scale: 255
shutdown_value: 0.0
Correct?
Yes, that is correct, so you would have to use the commands to set the pin; the M106 will not work with pin assignments.
Using Orcaslicer and it generates M106 for fan. How do I get around this?
Not sure for that slicer, I use Simply3D; in the script section you can create a search & replace.
I have a K1, no issues controlling parts and side fan with Gcode from Simply3D.
You might want to post in a Orca slicer group.
Okay, will do.
Thank you anyway!
Hi @Roij
Orca uses M106 command in order to activate some cooling fans and others.
These fans must be defined as fan_generic, not output_pins.
In my case, i have a IDEX printer, with multiple fans, so i had to redefine this command.
Anyways, i send you an example:
This is one of my fans:
# Filament fan
[fan_generic ventilador_capa_T0_IZQ]
pin: EBBCan_0: FAN1
kick_start_time: 0.5
off_below: 0.3
cycle_time: 0.01
I dunno if you need to redefine M106 for your purposes, anyways, in case it is helpul for you, this is my m106 configuration:
# Definition of variables for managing multiple part cooling fans.
[gcode_macro FAN_VARIABLE]
variable_active_fan: 0  # Default active fan is 0 (can be adjusted based on T0/T1 selection).
# M106 - ACTIVATE FANS IN IDEX
[gcode_macro M106]
# This macro overrides the "M106" command to allow control of multiple extruder fans in an IDEX setup.
# It dynamically selects the correct fan based on the extruder in use or based on the P parameter passed.
    {% set fan_vars = printer["gcode_macro FAN_VARIABLE"] %}
    {% set raw_speed = params.S|default(0)|float %}
    {% set fan_speed = (raw_speed / 255.0)|round(2) %}  # Convert fan speed from 0-255 range to percentage (0-1)
    # Select the target fan based on parameter P or the currently active fan
    # This allows the correct fan to be activated for the active extruder.
    {% set target_fan = params.P|default(fan_vars.active_fan)|int %}
    # Control the fan speed for the active extruder or based on the P parameter.
    # This ensures the correct fan is activated during printing, depending on the active extruder or mode.
    {% if target_fan in [0,1,2,3,4] %}
        ### Controls the print fan for the active carriage or both for mirror/duplication mode.
        CARRIAGE_PRINT_FAN SPEED={fan_speed} TARGET={target_fan}
[gcode_macro M107]
# This macro overrides the default M107 command to allow control of multiple extruders in an IDEX setup.
# It uses the fan control system to turn off the active fan for the current extruder, or the fan specified by parameter P.
    M106 S0 P{target_fan}  # Turns off the active fan by setting its speed to 0 (equivalent to M107).
# CARRIAGE_PRINT_FAN - ACTIVATION OF FANS IN IDEX
[gcode_macro CARRIAGE_PRINT_FAN]
# This macro automatically sets the print fan speed for different operating modes.
# It selects the correct fan and sets the speed based on the active extruder or the target fan specified.
# This macro is called via M106 and M107 commands and in the activation of extruders, via T0,T1, and mirror and copy modes
    # Determine the target fan based on parameters or use the default active fan
    {% if params.TARGET is defined %}
        {% set target_fan = params.TARGET|int %}
    {% else %}
        {% set target_fan = fan_vars.active_fan %}
    # Set the fan speed if provided, otherwise retrieve the current speed of the target fan
    {% if params.SPEED is defined %}
        {% set fan_speed = params.SPEED|float %}  # Use the provided speed if available
    {% else %}
        # If no speed is provided, get the current speed of the selected fan
        {% if target_fan == 0 %}
            {% set fan_speed = printer["fan_generic ventilador_capa_T0_IZQ"].speed|float %}
        {% elif target_fan == 1 %}
            {% set fan_speed = printer["fan_generic ventilador_capa_T1_IZQ"].speed|float %}
        # Possible part cooling fan for extra cooling purposes
        #{% elif target_fan == 2 %}
            #{% set fan_speed = printer["fan_generic cooling_part"].speed|float %}
        # Air extractor fan
        {% elif target_fan == 3 %}
            {% set fan_speed = printer["fan_generic ventilador_extractor"].speed|float %}
        ### For mirror or duplication mode, set the maximum speed between the fans of T0 and T1.
        {% elif target_fan == 4 %}
            {% set fans_T0_speed = printer["fan_generic ventilador_capa_T0_IZQ"].speed|float %}
            {% set fans_T1_speed = printer["fan_generic ventilador_capa_T1_IZQ"].speed|float %}
            {% set fan_speed = [fans_T0_speed, fans_T1_speed]|max %}  # Use the maximum speed between T0 and T1 fans.
        {% else %}
            # If no valid target fan is found, set the fan speed to 0 for safety.
            {% set fan_speed = 0 %}
    # Activate the appropriate fans based on the selected target fan.
        ### Fans on carriage X1 (extruder T0).
        SET_FAN_SPEED FAN=ventilador_capa_T0_IZQ SPEED={fan_speed}  # Activate the left fan of T0.
        SET_FAN_SPEED FAN=ventilador_capa_T0_DCHA SPEED={fan_speed}  # Activate the right fan of T0.
        ### Fans on carriage X2 (extruder T1).
        SET_FAN_SPEED FAN=ventilador_capa_T1_IZQ SPEED={fan_speed}  # Activate the left fan of T1.
        SET_FAN_SPEED FAN=ventilador_capa_T1_DCHA SPEED={fan_speed}  # Activate the right fan of T1.
        ### Possible auxiliary fan for part cooling
        ### Air extractor fan
        SET_FAN_SPEED FAN=ventilador_extractor SPEED={fan_speed}  # Activate the air extractor fan
        ### Fans on both carriages for mirror/duplication mode.
        SET_FAN_SPEED FAN=ventilador_capa_T0_IZQ SPEED={fan_speed}  # Activate all fans for T0 and T1.
Also, i need to activate the active fan in T0 and T1 calls so when orca commands just M106 and speed, it works properly:
For example:
[gcode_macro T0]
# Activate main extruder (T0)
    G91  # Set to relative movement mode
    G1 Z0.4 F1800  # Raise the head slightly to avoid collisions
    G90  # Return to absolute movement mode
    PARK_extruder1  # Parks extruder 1 to avoid future collisions
    ACTIVATE_EXTRUDER EXTRUDER=extruder  # Activates extruder 0
    SET_DUAL_CARRIAGE CARRIAGE=0  # Selects extruder carriage 0
    # Save the mode
    SET_GCODE_VARIABLE MACRO=MODES_VARIABLE VARIABLE=mode VALUE='"T0"'
    # Added for handling M106 fans
    SET_GCODE_VARIABLE MACRO=FAN_VARIABLE VARIABLE=active_fan VALUE=0  # Controls extruder 0 fan
    CARRIAGE_PRINT_FAN TARGET=0  # Activates the carriage fan
I hope it was helpful :slightly_smiling_face:
Hello @JuanR3D !
Please the Preformatted Text feature of the forum editor for your code. Without it, the code is absolute useless because spaces and characters are deleted.
Format
Oh, i didn’t know about that. I’ll have that in mind in all future responses.
Thanks a lot!!
