Printer Model: Ratrig Vcore3
MCU / Printerboard: Octopus + EBB42
klippy.log- Not needed
Not an issue
Until now I used Super Slicer, since it has very optimized profiles for the printer I use… But for a few days I’ve been using Cura, and it’s generally better than expected, I have two questions…:
1- I notice, they are very small, some micropauses when I print a gcode generated with cura. I couldn’t say exactly when they are. It seems to me that he does them when he has to move without extrusion… they are pauses of tenths of seconds, but I manage to perceive them. I guess it will be one of the 1xxx parameters it has. Does anyone know which one(s) they could be?
2- When I made the gcode with Superslicer, it gave me an estimate of times, which although they were not 100% exact, they were very close. But now that I do it with Cura, the times are not close, there are differences of 30% or 40%. I suppose that the limits that I have in the configuration of the printer, limit those of Cura… What parameters do I have to check that they are the same in Klipper and in Cura? (So that the times are similar)
Thank you
